i have recently bought a r33 gtst series 1.5
im brand new to owning a skyline and have never driven turbos before
i feel i have an issue with the cars performance however
it seems to lack power and a bit of it on the dyno it only put out 175.9rwhp
mods are front mount k&n pod exhaust n cold air intake
it has relitively new splitfire coil packs i recently purchased a turbosmart b/c
however when i hook it up it starts to boost normal and then dies as if the ecu (standard) is cuttin the fuel or spark
even when its turned all the way off so it has been removed
however the car still seems to be over fueling or watever
i have changed plugs, fuel filtet, cleaned a/f a/f hotwire tried a diff ecu still standard reset original ecu
and i removed stock 2 stage boost cause when stage 2 kicked it in it done nothin
any ideas would be greatly appreciated
sandman
https://www.sau.com.au/forums/topic/369096-problem-with-my-33-gtst/
it doesnt even half to be at a high rpm it dies at about half throttle
and when its not in if im drivin in fifth at half throttle doinn 100kph it does the same thing
and from time to time feels like the power is surging
what boost are you trying to run? do you have an aftermarket gauge to see what boost you are running? remember that the stock gauge doesn't read in psi and isn't that accurate.
my guess is that you are trying to run too much boost and the ecu is cutting the power. even with the boost controller wound all the way down this is probably still the problem. first thing to do would be to get a gauge to see what the boost is doing.
I still reckon its spark related if its still doin the same thing when u took me for a drive. Spark is deffo braking down, thats probs why it runs so shite when u try and put more boost in it. My vl was doin the same thing when i first turbod it, changed the leads and spark plugs and it fixed it. I thought u had fixed the problem?
Edited by Vl3lt
  • 3 weeks later...
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
