i have recently bought a r33 gtst series 1.5
im brand new to owning a skyline and have never driven turbos before
i feel i have an issue with the cars performance however
it seems to lack power and a bit of it on the dyno it only put out 175.9rwhp
mods are front mount k&n pod exhaust n cold air intake
it has relitively new splitfire coil packs i recently purchased a turbosmart b/c
however when i hook it up it starts to boost normal and then dies as if the ecu (standard) is cuttin the fuel or spark
even when its turned all the way off so it has been removed
however the car still seems to be over fueling or watever
i have changed plugs, fuel filtet, cleaned a/f a/f hotwire tried a diff ecu still standard reset original ecu
and i removed stock 2 stage boost cause when stage 2 kicked it in it done nothin
any ideas would be greatly appreciated
sandman
https://www.sau.com.au/forums/topic/369096-problem-with-my-33-gtst/
it doesnt even half to be at a high rpm it dies at about half throttle
and when its not in if im drivin in fifth at half throttle doinn 100kph it does the same thing
and from time to time feels like the power is surging
what boost are you trying to run? do you have an aftermarket gauge to see what boost you are running? remember that the stock gauge doesn't read in psi and isn't that accurate.
my guess is that you are trying to run too much boost and the ecu is cutting the power. even with the boost controller wound all the way down this is probably still the problem. first thing to do would be to get a gauge to see what the boost is doing.
I still reckon its spark related if its still doin the same thing when u took me for a drive. Spark is deffo braking down, thats probs why it runs so shite when u try and put more boost in it. My vl was doin the same thing when i first turbod it, changed the leads and spark plugs and it fixed it. I thought u had fixed the problem?
Edited by Vl3lt
  • 3 weeks later...
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
