We have to have a 36mm restrictor on the intake of the turbo, so this severly limits HP and rpm. Currently makes about 340rwhp @ 5800rpm with the restrictor.
The car is for sale, this is the list of mods
1998 Nissan 200sx, S14a series 2
The only S14a racing in Improved Production in Australia
Current lap record holder on Wanneroo Raceway short circuit
Body:
Paint by Damage Control Panel and Paint
Carbon Fibre Rear Wing, Gurney Flap and End Plates
Cwest skirts
Genuine front bumper integrated brake ducts with Luxury lower lip
Extensive Maitland Roll cage that links through the firewall to the front struts
All bitumen and seam seal removed
Seam welded
Interior:
Painted interior very well presented
Array of Autometer Gauges and LED Shift lights
AIM Lap Timer
Vello Race seat with head side restraints
OMP 5 Point harnesses
Engine 1: (currently out of car)
High Compression 11:1
Wiseco forged Pistons
Manley Racing Connecting Rods
Apexi Head Gasket 3 layer metal
ARP Bolts
Knife edged crank
ACL Race Bearings
Greddy Winged and baffled sump
Big $ Ported Head on flow bench
Angled Valves
Brian Crower Race Valve Springs
Brian Crower Titanium retainers
Race Cams and adjustable cam gears
ARP Mazworx Long Head Studs
Full Metal Jacket crank pulley
Engine Accessories:
Custom Garret turbo
6 boost exhaust Manifold
Apexi Racing External Waste Gate and screamer pipe
Big $$$ custom 36mm intake restrictor as per IPRA Regulations
Koyo triple N flow aluminium racing radiator
Very large Race electric Fan
Davies Craig Electric Water Pump
1.5ltr Expansion tank with 3 consistant bleeds of engine and radiator
Large Nismo fuel injectors
PWR Intercooler with light weight alloy piping
Braided lines used in engine bay
Bosch Fuel Pumps with undercar surge tank
HKS Oil cooler and remote mounted oil filter
Quick drain fuel adaptor
Driveline:
OS Giken twin plate clutch and light weight Moly flywheel
Nismo Roller pilot bearing
SR20 to RB25 Skyline gearbox adapter plate
New RB25 Skyline PAR Racing Straight cut Dog Gear box 5 speed
Skyline GTR Tailshaft
Skyline GTR Half Shafts
Skyline GTR Rear Diff with 3.7:1 ratio
New Nismo 1.5 way racing LSD (Adjustable tension)
4 x Enkei RPF1 light weight racing wheels 17 x 9 on car
8 x fresh 255/40/17 Yokohama A048 tyres
Electrics:
Haltech Platinum 1000 ECU
Full custom rewire
Warning lights for Oil pressure, Water Temp, Charge
Gauges for Oil Pressure, Oil Temperature, Water Temperature, Boost
LED multi stage Shift lights
Data logging ECU
Haltech adjustable boost controller, for in car adjustable
Suspension and Brakes:
Full Coil over with adjustable ride heights
Adjustable camber tops and upright mounting plates
Koni Racing independent bump and rebound adjustable Shocks
King Springs (Many sets of different spring rates)
Whiteline adjustable sway bar
All control arm bushes are polyurethane with excentric (offset) centres
Skyline GTR alloy rear uprights
Racing Roll Centre Ball joints and adjustable height tie rod ends
Front Brakes:
Wilwood 6 piston Billet Calliper
Wilwood 340x36mm rotor with light weight alloy hats
Rear Brakes:
Wilwood 4 piston Billet Calliper
Wilwood 309x28mm rotor with light weight alloy hats
Adjustable bias valve
Braided lines front and rear (No rubber anywhere)
Large brake ducts to center of rotors
Spare Engine:
Engine 2 (Currently in the car)
Wiseco Pistons 9.5:1 compression
Eagle Rods
ARP Bolts
ACL Race Bearings
Ported Head
Angled valves
Apexi metal head gasket
ARP Mazworx Long head studs
Spare Parts:
Spare RB25 Skyline Gearbox 5 speed
Spare Skyline GTR Diff 4.1:1 (Locked)
Spare painted Front Cwest Fibreglass bumper with large undertray
New spare Front Rotors
New spare Front Hats
New spare Front and Rear brake Pads
New spare Crank Angle sensor
New spare Apexi 3layer metal head gasket
8 new spare NGK racing spark plugs
New spare Electric Davies Craig Water Pump 110lpm
4 spare new Enkei RPF1 17x9 +22 rims
4 Spare coil packs
Spare igniter
Spare painted Rear bumper
$48000
Call
Ashly Barnett
0417 936 001
  • 3 months later...
