Hey,
Quick questions here.
I'm looking at purchasing a R34 GTR from sydney however i'm in SA so would like to get a mechanical check done before i fly there.
Would you go for CRD or just a NRMA check?
CRD is quite pricey at $440 but i'm willing to pay that if it's worth it.
Cheers, Jonno.
https://www.sau.com.au/forums/topic/369151-mechanical-check/
Hey,
Cheers, Jonno.
I hope you let the guy know your coming to have a look , i bought mine from NZ and brought it to S.A ,
have a good look at it yourself no need for mechanics to go over !!! .
i can give you a list of things to look at when buying !! If you want ????
Hey,
Cheers, Jonno.
A mate used to work for NRMA vehicle inspections (which no longer exist) and whilst being a great mechanic; due to his specialty Honda training, he was no GTR specialist.
Mostly the NRMA style inspections look for accident damage (repaired and unrepaired) and general wear & tear; as opposed to model specific issues. You might be lucky to fluke someone with some experience but by and large, you don't get to choose.
Surely you'd be better having someone who knows exactly what they're looking for, doing the job, especially with the potential cost in getting it wrong.
As you say $440 is peanuts compared to an engine rebuild if you weren't planning to do one...pinch.gif
Yeah i'd rather just have it checked over for peace of mind. Just saves me the hassle of flying to NSW just to look at it. If the mechanic report comes out bad i don't even have to bother wasting time and money flying there.
But a list would be good either way, cheers!
Yeah that's why i was leaning toward CRD, they KNOW they're GTR's.
Not being from NSW was just looking at feedback if there's elsewhere i can take it to? Or if CRD was the best choice.
Todd at Japlink.. He supports all SAU NSW members with many benefits/discounts and is as honest as it comes. Cannot recommend him enough!
Address: 175 Parramatta Road, Haberfield NSW 2045
Telephone: 02 9716 0857
Highly recommend CRD.
My beasty is there right now :(
Definately get someone to look at it, and not the NRMA.
No need for mechanics? So you can do a compression test yourself can you? I understand there are a lot of things you can check yourself, but there's also a lot you can't!
CRD, Powerplay Imports, Tune House, Dart, Just Jap, Unigroup Eng, JapLink.
We're well catered for here in NSW.
Just consider...
CRD, Powerplay and Tune House cost the most compared to the other 4.
JapLink is also a compliance centre (+ other positives that Aggroman kindly mentioned)
Some things u can do yourself :
  • Just park in neutral and rev hard to make sure theres no smoke out the back - black smoke = running rich/too much fuel?, sometimes it is the carbon/soot buildup in the exhaust that is released when hard-revving. Blue smoke = usually your piston rings are fked -steer clear, white smoke = burning oil / water I think.
  • Take it for a drive, brake hard, judge if the brakes are good, no wobbling, shuddering (rotors are warped), should brake clean and hard
  • Hard cornering - no funny noises, squeaks etc, should turn in nice and sharp, Judge steering feel, should be bit heavy and precise -point and go
  • Hard revving - should sound nice and clean and power should hold well in upper rpms, no flat spots/ back-offs etc
  • Check for exhaust rattle, turbo gasket rattle etc
  • No crunching of gearbox when shifting at high rpms - smooth shift
  • Again no funny noises anywhere
  • Check no uneven wear marks in tyres, check suspension is balanced
  • Check the usuals - lights, seatbelts, wipers, safety stuff
  • Airconditioning, fancy electrical stuff- check all these
  • Check body alignment by looking at an angle to see theres no accident damage etc, a trained eye you need for this..
  • Check all the fluids to see they are fresh - ie oil shouldnt be black - deep red is fresh oil
  • Ask when / if the timing belt was done
  • Taking it for a HARD drive is the best way to check that these systems are up to spec and can more than withstand abuse
  • Then pay a workshop 50 bux or so to do an engine compression test - very important
Thats as far as I know, Im no mechanic.. good luck
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
