Hi, my bf is planning to do an RB25DET silvia conversion. I was wondering if anyone here has any information or experience related to this conversion, or can add anything to his list so far that needs to be considered.
Cheers
SR20 Auto gearbox crossmember.
R33 Engine crossmember with R32 mounts.
Plenum will hit bonnet, chop support from under the bonnet or put spacers in.
FMIC and custom piping.
Aftermarket front and dump pipe.
3" exaust.
The sump will need massaging cause it sits just touching the sway bar.
Cant use the engine fan, need thermo fans prefably two of them.
You can keep the air conditioner.
Can use standard hydraulic lines and power steering lines
Use r32 radiator
Hoses are on the same side as rb25
Aftermarket ecu wolf v4 plus
Can get strut bar, but unsure what size will fit under the bonnet and clear the plenum
Tail shaft need custom to make it fit
R200 mechanical lsd
Throttle cable in SR is longer than rb25det, you can cut the SR cable or use the rb25 one
https://www.sau.com.au/forums/topic/36916-rb25det-silvia-conversion/
instead of chopping the shit out of the bonnet why not have the mounts lowered, which is what my car has had done.
every car i have seen has had to do away with aircon, and if you have a FMIC no chance either i reckon.
show me a strut bar that fits ill buy it!!! custom jobbie i reckon
Cheers
3" exaust.
Use r32 radiator
R200 mechanical lsd
-you need to use 33 mounts with the 33, sits lower and has 2 bolt pattern onto the xmember rather than 32 1 bolt
- you could 'massage' it, might cause problems with oil flow, better to space the sway bar from the body, about 10mm
- would also be good to enlarge/baffle sump while it's out
- might be wrong with the 25, but I think you 32 bottom (if using 32 radiator) and 33 top hose
- front pipe can use rb25 , fits into the s13
- can keep ecu, seen a lot of 25's eating it lately with wolfs but might be just me
that's all I can think of atm
  • 1 month later...
you are going to need a whole new computer, it would help to have a better gear box but if you use just a normal old clutch the clutch will go before the gear box how ever you will have to keep replacing the clutch buts thats better than the gear box. So i recomend you use a rb25 gear box(if she will fit which im not to sure about) a rb20det gear will fit and wil hold and is about 1800 dola cheaper. if i think of anything else ill give you a buz
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
