standard a R33 GTST makes nearly 250hp so on anything but a bone standard car 2.5inch is a waste of time. 3 inch (76mm) is the smallest exhaust you should be looking at for a 33 GTST. better even to go straight to 80mm which is a touch bigger.
+1
295 at the wheels is close to 350 at the engine ..Your exhaust flows engine hp not wheel hp..
+1
As for decent split dump systems. A good split dump would be great but ones that the pipes don't match up the turbine outlets (almost all of them) would create massive turbulence issues. A good split dump require the flange to be well adapted to the turbo outlet. The 2835 Pro S split dump is short but looks really well made, I'm sure that is part of the reason these turbos respond so well on the RB25.
I've changed to a bellmouth and I prefer the sound it makes - without the whooshing from the wastegate.
Edited by simpletool
  • Replies 48
If a GTST can run 9psi in standard form, how is the standard exhuaust too restrictive?
engines are in fact air pumps, the more air you flow through a motor the more power you are making. volume counts, not boost level. you can boost up on a restrictive exhaust but you won't make much more power, diminishing returns set in because backpressure in the exhaust starts to balance the boost you're feeding in.
Yes, your boost pressure is actually a measure of your engines inefficiency at processing air.
Not exactly. It's not airflow through the engine that matters, but rather the actual density (or oxygenization) of the air being drawn into the cylinder that determines how much fuel you can add, and thereby how much power you can make. that's why MAF sensors measure the Mass of the Air Flow, rather than the volume, and why there's a temp sensor in the intake for compensation. You could easily go up in CFM, but actually lose charge density per firing.
I agree unreservedly that boost level is largely irrelevant- only a muppet would think it's better to run 30psi for 600hp if the same engine could make the same power anyway on 25psi (and i know some people seem to think it's some kind of 'street cred' to have a huge boost number.
not exactly. it's not airflow through the engine that matters, but rather the actual density (or oxygenization) of the air being drawn into the cylinder that determines how much fuel you can add, and thereby how much power you can make. that's why MAF sensors measure the Mass of the Air Flow, and why there's a temp sensor in the intake for compensation.
I agree unreservedly that boost level is largely irrelevant- only a muppet would think it's better to run 30psi for 600hp if the same engine could make the same power anyway on 25psi (and i know some people seem to think it's some kind of 'street cred' to have a huge boost number)
Yeah, I don't think he was arguing against that in what he said, I guess the default assumption is "for a given intake temp"
and on the second point there is another large community where that is pretty prevalent Lol....
Geeze I am glad this article was posted up, seems as though the outcome most people have come to is to buy 2.5" exhausts??????????
You realise it has 3 paragraphs explaining why bigger is better. Only negatives can be sound, so get something thats not loud but still flows well.
Right......
So........
"Hi, is a 2.5" exhaust big enough for standard boost on a 33 GTS+T?"
"Nah you need a 3" exhaust"
"Um, ok, didn't GTST's come with 2.5" exhausts standard?"
"Nah you need a 3.5" exhaust"
"I don't understand the point of a 3" exhaust, I only want to run near standard boost, meaning near standard flow INTO the engine, equaling near standard flow OUT of the engine, about ~10psi, a stock GTST exhaust can flow sufficient exhaust gas created by the burning of the air-fuel mix that the engine induces running the flow generated into the engine at 9psi, so surely a mandrel bent 2.5" system with a good cat and mufflers should do the same if not better job, I can't run much more than that anyway being a DE+T"
"You'll need an 12" exhaust"
"That doesn't make sense to me"
According to the experts here, the best option would be to to run a 5" in-case i go to 500kw later?
QUOTE:
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.�
To get my car to the 250hp mark, it needs alot more than a 3" exhaust. Such as a decent inter-cooler, engine management and probably a clutch, at the very least.
I'm not arguing that a larger exhaust on a turbo car is a bad thing, apart from the noise, and to a certain extent the loss of low-mid range power. I understand the principle that you want as much pressure in front of the turbo as practical, and as little as possible behind.
I'm not arguing that pressure and flow are un-related, pressure is flow vs. a restriction, currently the car drops 1.5psi towards red-line, primarily, I suspect due to still running the N/A center section of the exhaust, thus, i'm changing it. I want 2.5", for now, as it will suit my current goals and not be excessively loud and attract attention.
If it turns out that it is too restrictive, then i'm down $200, go to 3", job done. The mufflers and cat I now have will support this, with the addition of a different dump/front pipe.
If not, and it holds 5psi from 2500rpm to red line, then i'll be happy.
The guy doing the job makes a living out of building exhausts, doesn't have to advertise due to word-of mouth, and knows his stuff, if he believes that 2.5" is enough as he has convinced me, then i'm happy to give it a go.
If i'm proven wrong, then it's my mistake for not listening to the guys with the 4 figure post counts and a list of peak power outputs for certain turbos sitting next to their computer.
If anyone has bothered to look at my original post I asked what size the factory dump/front pipes were..... Why does every thread have to turn into a shit-storm.....
2.5 is fine.. My car made close to 300 engine hp (185rwkw) with a 2.5 inch exhaust standard intercooler and turbo on 11psi..
But a 3 inch doesnt need to be loud and is just as good and if you do want more power later you wouldnt need to change it... But now you do.. :)
I really dont care what you do though, u asked for advice and we gave it..
But I didn't ask for any advice, I asked what size the standard GTST dump/front pipes were.....
I'm not fussed if I do have to change it either way, as it's not the most expensive part of the project. Whatever happens, i'll deal with it. thanks.gif
What leads you to believe there will be a loss of midrange power?
This isnt a shitstorm. Relax bro.
Also, you could;
1. get the 2.5in exhaust
2. get dyno run with it on, then another with it dropped so see if there is any power difference
3. post the result for the good of the community
"I'm not arguing that a larger exhaust on a turbo car is a bad thing, apart from the noise, and to a certain extent the loss of low-mid range power. "
short video stock 3'inch with dyno, just need a 2.5' one now lol
Edited by nismo07
Also, you could;
After searching around here and the net generally, *some* believe that there is a small loss in power across certain RPM with different size exhausts, even on turbo cars... I'll try find links.
I am relaxed, "I ain't even mad", I originally said "2.5" is good for 250-300hp" that's more than within my goals, 2.5" will suit and hopefully sound nice without causing problems, asked what size the factory dump/front were, then got molested by the 3" warriors.... tongue.gif
And yes, the plan is to dyno the car once the exhaust is done and boost controller on, not only to see what it's making now, but how much can be extracted before detonation or leaning become a problem...
As i've said, repeatedly, i'm not fussed if the pipework needs changing after a dyno run, i'm happy to deal with the consequences.... thumbsup.gif
Edited by blk94r33
250hp at the engine is only roughly 150rwkw. That is what a standard RB25DET makes.
A normal setup with a few mods is around 190rwkw so as said by Arthur thats around 300hp at the engine. So going by the quote of 250-300hp you will be right at the end of the range. The article goes into great detail about why having a larger turbo back exhaust can only improve things. So if you are getting a new exhaust made then by the logic of the article you would get a 3" exhaust. You can say you dont care about the article, but then why are you posting in this thread?
I never said I don't care about the article.
I'm posting here as I wanted to know the size of a standard dump/front pipe, and it was the only exhaust thread getting replies...
Good on you for striving to do your own research/experimentation to satisfy yourself that you've done it right - there IS a lot of BS and misunderstanding on the internet and its self propegating, I wish I worked out way earlier that even a lot of the more clued up seeming (and sometimes actually are mostly switched on) people have holes in their understanding of things, no one can have all the answers. A lot of the time given explanations for a rule of thumb which is correct are wrong in terms of reasons, and thats where things can go awry.
Having said that, all things being equal (no compromising bends, equivalent mufflers etc) I am absolutely sure that going to a 3" or bigger exhaust will cost you nothing anywhere versus a 2.5" system on your car. Any loss in torque anyone has experienced with a turbo car as a result of changing exhaust would more likely be tune related, or some other issue - especially if the airflow (in an airflow metered car) reaches levels which there is overly safe mapping for in that particular instance.
Bare in mind when changing a cars setup that there are always all sorts of variables at play, don't always assume that the most obvious thing (or the first thing you think of) is actually the cause of the final outcome.
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
