My R34 GTR is for sale check out the following link.
http://www.carsales....13899&__Ntt=r34
The car is in excellent condition and has always being garaged. All the servicings have being done as required with a log book. The car was tuned at Mildern Automotive and made 276 rwKw on a Mainline dyno at 16psi. Only held back by the stock turbos.
AV input so you can plug in you DVD Player or Phone and it will display on the Screen and the audio will play through the car stereo system.
GTR Floor mats Front & Rear but the Carpet is Brand new under the floor mats.
The car has $30,000 of Extras including many NISMO items, as follows
NISMO Supper Copper mix Twin Plate Clutch,
NISMO High Flow Fuel Pump,
NISMO Front Bumper,
NISMO Oil Cooler,
NISMO MFD Version II (G-Meter, Lap Timer, 2 Bar Boost Gauge, Laptop Hook up),
NISMO White 320km Dash (Changed at 55,000Km Car total is 75,000Km),
NISMO Air Flow Meters,
N1 Water Pump,
NISMO Low opening Thermostat,
NISMO Timing Belt,
NISMO Clutch, Brake and Throttle Pedals,
NISMO Oil Air Separator,
Kakimoto N1 Full Dual Exhaust,
HKS Hard Piping,
HKS Racing PODS,
Lightened Flywheel,
BBS RGR Diamond Black Wheels 18x9.5,
Kuhmo KU36 Tyres,
ARC Sway Bars Front & Rear,
Bilstein Suspension,
Project Mu Brake Lines Front & Rear,
Project Mu SCR-PRO 2 Piece Slotted Front Brake Rotors,
HDI RS-SPEC 4" Intercooler,
Oil Filter Relocated,
Cusco Brake Master Cylinder Stopper,
Digital Wide Band O2 Sensor,
880cc Injectors,
Power FC with Hand Controller,
Blitz Daul SBC Boost Contoller,
Custom Air / Water Bleed System (Swell Pot, Header Tank),
Spitfire Coil Packs,
High Flow Metal CATS,
Koyorad Radiator,
1KG fire extinguisher,
Tinited Windows,
I have most of the Stock parts and they can be sold with the car if the buyer wants.
I also have a Brand new set of Garrett 2860-5 turbos, Genuine R34 full engine gasket kit, ARP Exhaust manifold studs, nuts, washers and a complete set of turbo studs, nuts and a ATI 1000Hp Super Balancer. All of the items can be negotiated in to the price of the car.
Call me any time on 0401 469 148
Price $53,500
https://www.sau.com.au/forums/topic/369187-r34-gtr-1999-v-spec-for-sale-sa/
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
