Im about to install all the adjustable camber castor traction rods in my car and want to find somewhere to take it that can adjust it to the settings I give them. Ive heard that that the normal places like tyrepower kmart bob jane etc. don't really do a good job when it comes to doing a specific setup with all the adjustable gear due to there equipment not being that good is this true?
But anyway whoever has a good place that they have had adjust there alignment settings with all the adjustable gear let me know.
Thanks
https://www.sau.com.au/forums/topic/369200-good-wheel-alignment-places/
definitely Traction Tyres - don't add extra 0's onto the quote just because they're performance orientated, unlike some other performance suspension workshops
Will give good prices for SAU members as well :)
Try Craig from Trackside in Bayswater.
He did an awesome job on my 34, took his time and did it properly unlike 90% of places out there, he does alot of old classics and track cars so he knows his stuff.
Lol a mate at work took his 4WD to a place and they actually asked him what that bar was that runs from his diff to the body, there are some shocking places out there so be carefull who you take it to.
Edited by eightsixboy
I went to jax quickfit in seaford when i put my adjustable camber arms in, tried to get into a few know places but were all booked up or i couldnt get there when they were available, decided just to take it to a normal place as i only wanted tyres changed and the rear camber arms adjusted, they have the wireless machines for each wheel and asked me what i wanted the camber and castor i wanted it adjusted to, erik is the guy to see and is also a skyline owner.
Just need to make sure they have a hicas lock bar for the alignment, I took my car down to tyrepower in rowville for a 4 wheel alignment and they did the front then were like ohhh u have hicas ... eerr we dont have the lock bar thing to do the rear alignment :S
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
