Hey guys,
Recently am in need of some new tires, pretty standard size, 235/40/R17. I got a quote from a dealer in Blackwood, for some Toyo Proxes 4's, as I am wanting to give these a go having just come off of a set of Dunlop LM703's. Has anyone driven the Proxes 4's? What did you think of them? Also, where is the best place to get these in Adelaide. I got quoted $230 each.
Cheers guys!
https://www.sau.com.au/forums/topic/369203-toyo-proxes-4/
No actually, I didn't. I believe they were on special or something, and thought it was not too bad. I haven't checked anywhere else out and was not sure if it was a good price or not. Do most tire shops offer discount for club members? Or are there specific dealers for SAUSA members?
https://www.sau.com.au/forums/topic/369203-toyo-proxes-4/#findComment-5885375
Hey guys,
Cheers guys!
for that price, I'd recommend upgrading to the T1R Proxes ... they're around $250 a corner (at least for the 225x50/r16) so I'd imagine it'd be not much more than what you'd already be paying for the 4's
Been running T1R's for the last 4 years and they are a brilliant road compound. I get 2 years out of mine before camber wear is an issue.
-D
https://www.sau.com.au/forums/topic/369203-toyo-proxes-4/#findComment-5892552
t1rs are just a normal road tyre, proxes 4s are higher, then r1r higher again before you go an r compound.
hrm. always thought the p4s were cheaper due to being a lesser compound.
the review comparisons seemed to favour the t1r's however, especially in the wet
-D
https://www.sau.com.au/forums/topic/369203-toyo-proxes-4/#findComment-5892613
  • 1 month later...
I ran the proxes4 on the rear of my old r32 rb30det running a shade over 300rwkw. Hooked up second relatively well and third damn well. 0-100 was an effortless 4secs flat.
Tried quite a few different tyres sizes etc. Settled on the standard 225/50/16's over a set of decent 255 18's that were like sliding on ice in comparison.
IMO great tyre, great wear, nice centered feel but with a slightly soft sidewall - which is great for straight line though. :)
https://www.sau.com.au/forums/topic/369203-toyo-proxes-4/#findComment-5946544
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
