My 1994 R32 Gearbox is very tired, the return springs are worn out or loose or something, the synchro's in a couple of the gears are worn out, and there is a horrible bearing noise or something that i havn't been able to locate and i think its also coming from the gearbox. So im looking at replacing it with a brand new standard item, im not at all interested in buying second hand or even restored.
I thought about rebuilding it with with PPG's or similar but i don't want to spend the $$$ where i don't have to.
Is there a known preferred place to buy brand new? The only place i know about is justjap.com and they have them for $3300. Are there any other Australian suppliers i should try?
Thanks,
Shaun
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/
  • Replies 40
I believe that would be the case. Last time i checked i could get one delivered through RHD Japan or Nengun, can't remember which one, for about $3000 delivered. But i am happy to support an Aussie company if they can do a good price.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5885538
An option is the series 3 R33 box (at the same cost last time i looked), and swapping the bellhousing on your existing box. That way you get the updated series 3 internals (IIRC extra synchros on 3rd and 4th, and a few other things).
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5886410
That sounds like a good option. Do you know if the final gear ratio will remain the same or similar? Im pretty green when it comes to GTR's and what fits and what doesn't. I come from a background of WRX's..
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5886655
yeah all the gear ratios 1-5 are the same in R32 and R33 and final drive (in this case the front and rear diff ratios) are the same in R32 and R33 as well (4.111:1). I would just go with the nengun or RHD box. in fact if you order an R32 box chances are it's an R33 S3 box just with 32 bellhousing as they don't make a number if the internal parts for R32 boxes anymore so all are probably built to the later spec.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5886658
Interesting.. I will have to contact RHD and see what price they can do as they don't have them listed on the site. In terms of taking the box out, if using a hoist would you suggest dropping the motor and gearbox together or just doing the gearbox on its own? I will be doing a few things like engine mounts, hoses, etc at the same time.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5886746
It's a straight six motor which is long itself, coupled to a ridiculously long gearbox.
I tried to do an engine r&r with the gearbox in and ended up bending a clutch plate.
If I had to do it again, I would prop the car up as high as I could (front and rear wheels) with engine stands and 10 layers of redundancy for safety.
Then I would uncouple the rear shaft, loosen the engine mounts and let the gearbox drop slightly to get to the top 2 bolts.
Then I'd undo everthing else, (front driveshaft to transfer case) and put a trolley jack under the gearbox to take the weight.
Then, with a friend, undo the rest of the gearbox bolts and slight it out.
I think other people have done it with engine and trans attached out the bonnet, but I just couldn't see how it was possible myself.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5888171
By the sounds of that i will take it as it comes..
New box from RHD Japan is $2850 delivered, plus taxes i suppose.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5888551
JAGR33 is selling a 500km old reco S3 gearbox, whilst not "brand new", its as close as you'll get.
Thanks but no, I have had the worst luck with second hand parts so I'm willing to pay more or "get ripped off" to be safe. Bought a set of $3500 coil-overs once (bought for $1500), I was showed a reciept showing they were purchased 6 months prior, they looked spotless.. Turned out all but 1 had to be rebuilt at $650ea. But here's the kicker! The Australian company wouldn't supply parts as they weren't bought from an "authorised" dealer.. enough said really!
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5888692
Well was just a thoughy, Jack has one of the best trader ratings on SAU for a reason :thumbsup:
Also just thinking, as you mentioned PPG...
Dollar for effectiveness you'd be better of spending a little more and putting a O/S gearset in, compared with dealing with a stock Nissan item.
A stock box for 3.5k - that is still has all the weaknesses...
Or a O/S set for IIRC ~5.5k.
Seems plenty of people have been having issues with other brands of gearsets... A simple browse in this section will give you an idea of such brands... So going with the tried and proven O/S might be another option to consider for you as you've clearly thought about strength for some reason.
What power/setup is in the car now?
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5891661
I am 99% sure Justjap don't have new boxes in stock any more (although feel free to check!), I bought one from them a few years back, but I understood whole new boxes can't be sourced any more. The rebuild I did since then I just put new synchros and bearings in a second hand box, it came up as good as the new one.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5894941
The car has twin 2860-7's producing 330kw at the rears, so basically at its max safe limit. As far as im aware the stock box should cope well enough at that power level? I know how to treat a gearbox well, I had a twin plate clutch in a 5 speed WRX making over 200kw and didn't break it, and they are notoriously weak :)
Since I have owned the car i have not enjoyed driving it as it has never been trouble free. At this stage all i am looking to do is get it reliable and fun to drive and then modify from there. If future upgrades require a strengthened gearset then i will do it then, but that wont be for a few years.
At the same time i'm doing the gearbox im putting in a new clutch, the OS Giken Street Master caught my eye, do you know anything about them? It seems they are a new offering and there's not much info on them available. They come to $2150 delivered. http://www.rhdjapan.com/os-giken-street-master-clutch-kit-twin-metal-hard-with-converter-kit-64963
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5895197
Thanks Duncan, I will check with them to see if that's the case.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5895201
Ok ye not a box busting setup.
Still... 2nd hand geaxbox i think is still the way to go. New Nissan is horribly expensive :/
As for the clutch, never heard of that actually.
But if you do want what is IMO the best clutch you can get - Nismo Coppermix Twin, drives like a factory clutch but has held fine with me 7000-7500rpm launches @ 350-380rwkw consistently without fail for 6 months now, it LOVES it.
And the pedal is very light compared to others i've used/had (ORC twin, O/S Racing Twin etc). Only thing that comes close would be a Jim Berry special single plate.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5895205
Thanks, I don't find the new GTR boxes expensive, even the 6 speed Getrag is cheap compared to the Subaru 6 speed. I did think of the Nismo clutch, i think they are about $2800 which is more than i wanted to spend but i will definitely keep it as an option.
https://www.sau.com.au/forums/topic/369217-r32-gtr-gearbox/#findComment-5896750
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
