NISSAN SKYLINE R32 GTR 1990 MODEL
APEXI POD FILTERS
LIGHT WEIGHT RACING WHEELS
LIKE NEW TYRES
GP PERFORMANCE ALLOY RADIATOR
R33 GTR FRONT MOUNT
PIGEY BACK COMPUTER
RDA DRILLED AND SLOTTER ROTORS NEW BRAKES
FRONT STRUT BAR
STAINLESS STEEL APEXI FRONT PIPE
3 INCH EXHAUST SYSTEM WITH CANON MUFFLER SOUNDS GOOD
ALSO VERY QUITE EXHAUST WAS REMOVED WHEN I PURCHASED THE CAR CAN BE WELDED BACK ON
CAR HAS JUST HAD A FULL SERVICE INCLUDING NEW PLATINUM PLUGS AND CASTROL EDGE OIL
CAR DRIVES GOOD HAS GOT 6 MONTHS REGO
CAN HELP BUYER WITH A RWC ONLY FOR A NAME CHANGE YOU PAY ME THE TRANSFER FEES
AND I WILL TRANSFER IT IN TO YOUR NAME RWC STAYS WITH ME
OTHER WISE ONLY REGO NO RWC
ORIGINAL GTR KEY
ALARM AND KEYLESS ENTRY
SONY SOUND SYSTEM / SPEACKERS / CD PLAYER / I POD INSERT
PAD POINTS
CAR HAS SIGNS OF RUST AROUND THE REAR GUARDS BUT HAVE BEEN TO PANEL SHOPS AND CHEAP TO FIX WAS QUOATED BETWEEN
$300 AND 400 PER SIDE (REPAIR AND PAINT)
DRIVERS SEAT TORN BUT HAS BEEN SOWED UP
HAPPY TO HELP INTERSTATE BUYERS WITH TRANSPORT
CAR IS LOCATED IN MOORABBIN VIC
ANY QUESTIONS PLEASE CALL ME DONT REPLY VIA SAU AS IM NOT ON THE NET MUCH THANKS
$10,000
CALL 0421 747 055 ANYTIME
Edited by r32vspec11
