Sellingparts from a high horsepower build. Allparts are brand new, never been run. All reasonable offers will be considered. Serious buyers only.
* Trust T88H38GK 22cm Complete Turbo Kit, turbo, manifold, wastegate, dump pipe, intakepipe, 2 x Trust pod filters, 100mm intercooler and stainless steel piping. This will also include a GReddy Type R blowoff valve which has been plumbed back into the intake. The wastegate has also been plumbed back intothe dump pipe. All Brand New.
$8000.00
* Hypertuneplenum chamber, Hypertune 83mm throttle body, Hypertune Fuel rail, Sard 1000ccinjectors, Speedflow fittings and braided hose for dual feed rail. All Brand New.
$4500.00
* Tomeiadjustable cam gears, pair. Brand New.
$370.00
* PWR triplecore radiator with 16inch Spal thermo fan, suit r33. Brand New.
$850.00
* PWR 14 rowoil cooler. Brand New.
$250.00
* ATI SuperDamper harmonic balancer. Brand New.
$620.00
* HKS TwinPower DLI ignition amplifier. Brand New.
$580.00
* Sard RJfuel pressure regulator. Brand New.
$260.00
* Motec M600,Advanced Data logging enabled with Motec 9 stage boost switch, wiring to suitR33.
$4800.00
* Cusco 6Point bolt in roll cage. Second hand,great condition.
$750.00
* CustomUnderbody surge tank with twin Bosch 044 fuel pumps, suit r32/33, s13/14/15.
$800.00
* Chromeplated coil cover with Tomei badge.
$200.00
There is a built engine also for sale, PM for details.
More Pictures to come.
I'm trying to keep it all together mate, if it doesn't sell anytime soon I will consider parting it out separately so i'll keep it in mind. Thanks.
Hey mate would u sell the injectors separate? Got a mate who would b interested if u will
  • 4 weeks later...
  • 4 weeks later...
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
