is it possible that the ecu has a problem cause the car still runs and relay is working...or could the ecu say f**ked up relay before it will f**k up?^^
i gonna get a new relay the next days but i just don't understand this here :happy:
sombody an idea?
Edited by o0o
Some of the relays near the fuse cluster are the exact same plug type and numbers...should be for headlights / tail lights, etc,....ie not neccesary to run.
Swap the over see if that works.
Possible that the ECU is the problem....reset the ECU (clear stored codes) and see if the code returns.
What exactly is the problem and how did you test the relay?
Diagnosing the relay is pretty simple.
Turn the igniton on, if the fuel pump primes then it's doing the first half of its job,
Flick the starter motor over a couple of turns, if the fuel pump primes again, then it's doing the other half.
If it's not priming fuel, and the relay IS working fine (or you test out another relay and it still isn't pumping fuel), then you could have a short on your fuel cradle ('sender'), on the tank, or somewhere on the loom going to the relay.
Edited by Nic_A31
actually there is no problem,...it was just i had nothing to do lol :whistling:
i checked the ecu for some errorcodes and hoped for no errors^^
but then came error for the the pump relay...
i did what you said and exchanged the relay with a another from under the hood it works fine, with the new relay no errorcode...today i switched the old relay back in its old position and checked errorcodes again and now no error with the original relay?
its getting confusing >_<
as far the car runs without problems its ok for me:D
@btw big thx on nic...you already helped me on alot problems now
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
