I got a set of wheels I want to send back to Aus. How do people usually send big items back?
I could send it via EMS. There's a limit of 30 KG and if I take the tyres off them they're easily under that. Then there's the issue of maximum volume allowed for the box which is also a pain.
Is there a easier method to send them home? If anyone knows please help me out.
Cheers,
Mike
https://www.sau.com.au/forums/topic/369295-shipping-from-japan-back-to-aus/
U can sea post wheels. I sent a set of TE37 18x10.5 back but had to take them out of original boxes and make the packing round to fit under the posting guidelines.
Btw tyres will need to either be sent seperate or taken off before shipping as they are to big.
Depending on their size send them Sea Post but you will be limited to size as all cubic dimensions must be no more than 200cm's max thus you will have to do what Luke said and repack around so they can go.
Dont worry if you get knocked back just try another post office. Just make sure they go as 4 separate parcel and make sure you packed em properly..a square rim box will not go.
Also dont send them the same day if they are going to be worth over $1,000 as you may get stung import duties. Customs are not dumb, so sending 4 brand spankers and under quoting them could see you forking out some duties.They are still blitzing on this at the moment. Just send 2 one day and another 2 the next.
Also its worth throwing on insurance..its about 6-800yen extra to insure for 80,000yen.
If you have any questions flick me a pm or if you can wait 2 weeks you can call my ketai. I'm out of Jappa for 2 weeks sorting some stuff out in Korea just pm me for number.
Heres some info from Japan Post site
http://www.post.japanpost.jp/int/use/parcel_en.html
i havent been able to send anything bigger than about a 17x9.5 through sea or SAL recently. theyve been going nuts!
another option is to send it with kuroneko yamato. pack two wheels together and it fits in the biggest size. will set you back about 53000yen i think from memory.
What Mark said about sending 2 one day and 2 another. You may want to send to seperate address as the ship ships every 3weeks I'm sure so sending 2 one day and 2another you will still be stung for tax, EMS is ok for doing that tho.
Not always as Sea Post gets sent to Kawasaki depot and will depend on when it gets sorted which ship it leaves on.
But yeah way better for different addresses or send a few weeks apart.
The other thing to look at when devaluing is parts to avoid customs duties is you will only be ably to insure to the devalued amount and if it goes missing in transit then the insured devalued amount is all you will recoup.
Saying that Japan post is extremely reliable and efficient it seems when it gets to Aussie Post that the wheels seem to fall off the cart.
End of the day if your buying through the right people in Japan you should be getting your parts at a cheap price including import tax & gst.
  • 4 months later...
  • 1 month later...
"fun-in-a-bin" I think he's having you on mate lol
No not having him on..
Chuck the kanji 船便 into a translator and you'll see the meaning for funabin means shipping service.
  • 1 month later...
hey guys i'll be in japa on march 14th and was planning to buy alot of parts, especially wheels. Would it make more sense in this case to post it via container (shared)? or else what would be the most economical way? Thanks
Cheers,
Kev
  • 1 month later...
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
