Hey guy'z I'm looking for a bigger spoiler for my r34 or just to make my stock one bigger what's every1 thing of this leg lifter things and would it be just a easy Swap-Over ? or can anyone tell me or show me something that would look good , heres a link to what im looking at http://www.ebay.com.au/itm/Nissan-Skyline-R34-GTR-GTT-Carbon-Spoiler-Leg-Lifter-/320679162274?pt=Race_Car_Parts&hash=item4aa9f7b1a2#ht_1479wt_1144
https://www.sau.com.au/forums/topic/369323-r34-spoiler/
Your attachment didn't work for me. But from your first post and that link to ebay, that spoiler stand will only work with a GTR spoiler... And since your's is a GT/GTT spoiler, it's not gonna work... Don't know why it would say GTT lol. Because the base of your spoiler, where the 2 screws goes, isn't levelled.
Maybe you can consider a set of Nismo Wing Stays, which rises the spoiler by maybe 40-50%?
Here's a pic of it on my car:
https://www.sau.com.au/forums/topic/369323-r34-spoiler/#findComment-5888750
The ones from Carmate is "Nismo style", mine is genuine Nismo :P
Got mine for $100 posted, 2nd hand (bargin :D). But I know brand new from rhdjapan is like $500-600.
Those pics on their website are actual Nismo wing stays.
And the reason why it doesn't look higher is because they used the mounting panel on the bottom, where as I didn't use mine, which I think looks better, it's also because I cbf painting it lol.
https://www.sau.com.au/forums/topic/369323-r34-spoiler/#findComment-5888891
Bloody hell charles, how do you always manage to score the good deals!
I'm still trying to find the same lip as yours... Called up over 3 hundred million places - Only carmate seem to have them and I ain't paying $550 ($350 item+ship + $200 paint+install) for a front lip... May as well get a whole new front bar.
https://www.sau.com.au/forums/topic/369323-r34-spoiler/#findComment-5889303
I'm on the forums too much haha.
But I wouldn't get a fibreglass one... They fit pretty badly.. I know, coz mine is fibreglass.. I sold a genuine one awhile ago.
https://www.sau.com.au/forums/topic/369323-r34-spoiler/#findComment-5889325
Tried DMD? They are in coopers plains.. have another office in moss st now i beleive.. if i recall you are in algester right? not too far away from either place.. they might have something or can get it in
https://www.sau.com.au/forums/topic/369323-r34-spoiler/#findComment-5889483
I checked out their website I didn't call them. I actually forgot about those guys, I will give them a call - Thanks for reminding me haha.
What a memory you have! I was at Algester about 2 years ago when I had my 33. Moved towards Forest Lake since I purchased my 34
https://www.sau.com.au/forums/topic/369323-r34-spoiler/#findComment-5889512
Yea i might as well just get the ones off carmate do the look the same as real nismo 1s ? like can you tell them apart , thanks
They look exactly the same because they used photos of real Nismo ones? lol
I've never seen a set in person from carmate, so I can't tell you :)
Maybe get it and post some pics up haha
https://www.sau.com.au/forums/topic/369323-r34-spoiler/#findComment-5890357
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
