Inverter type 160amp welder
Toolex industrial series. Approx 2 years old.
post gas control
HF start
Base current control
AC balance control
Slope down amperage
2T & 4T trigger
Can acept an external pedal controller
Brand new BOC 6m lead set with flex head torch
New gas saver lense kit fitted to torch
New argon flow meter and fixed reg
I've had this machine since new, it was used for weekend cage work and recently I've been doing alot more welding so I've upgraded to a larger water cooled machine hence the sale of this machine.
It's welded 10mm alloy plate and can handle >3mm piping without any hassle. It's surprisingly good with alloy once setup properly.
I've used it primarily for steel and Molly DC welding and the odd surge tank, sump or fuel tank etc.
Happy to give anyone a demo of it's capabilities, machine is in perfect condition not a mark on it always been covered when stored and looked after.
Located in Sydney pick up preferred.
I'd like to get $1400 for it. It cost me $3200 plus the boc lead kit $386.00 and the reg/flow meter $300
I'm happy to hire another argon cylinder and keep it as a 3rd welder if it doesn't sell.
Probably has other features I've forgotten photos to come
https://www.sau.com.au/forums/topic/369333-160amp-acdc-tig-welder/
