I did a quick search and couldn't find any useful infomation on this conversion.
If you know of any good links could you please list them as I'm after all the information I can get before I start the conversion.
All help would be much appriciated!
The motor arrives tommorow and I was wondering what I have to modify to make the motor fit.
Reading Zoom they said one of the engine mounts fouls on the turbo: Can I use a gtr engine mount?
Do only the holes in the sump for the drive shafts need to be filled or does it need to be modified in other ways? I'm wanting to use the gtr sump to stop oil surge.
Is it easy to remove the front diff?
Can i still use the RB20 throttle cable?
Do the gtr front pipes fit?
Does the gtr loom plug straght in?
Some may say why do this conversion? If you pick up a complete R32 gtr engine for $2500 missing afm's it seems pointless screwing around modifying a RB20 to still only have a 2 litre.
https://www.sau.com.au/forums/topic/36934-doing-rb26dett-r32-gtst-conversion/
You'll find that the rb26 sensors reads differently to the rb20s and yes used the gtr engine mounts. Throttle cables is ok and no the gtr-gts looms are different in r33 dunno about r32. But the real question is that have u started the engine u bought yet? cause it no point shoe horning in a busted engine and then having to remove it for rebuild, Don't just take an importer words as gospel. Also u have to get new sump as the stock gtr with block out are a eng- cert. nightmare.
Unless yours is a GTS4 then the pan rails on your sump are different to the RB26 so the options are limited.
Don't believe the GTR sump doesn't surge and if you are using the original RB20 box then it's life span will be in minutes once you crank up the boost.
I think you will find a fair difference between the two wiring harnesses and I assume you got the GTR computer ?
You can run aftermarket but if staying with factory then the afm's will be needed.
Cheers
Ken
if you change to a new ecu then you should be able to use the std loom may just need to change a few plugs. You will need to use the rb20 engine mounts and as ken said the rb20 box will be useless, change it to a rb25 one first, the front pipes should be fine as the body is very similar.
4WD RB series blocks have 2 sets of bolt patterns tapped into the block for sumps - both 4WD and 2WD sumps bolt up. The oil pickup needs a bit of work, as the location is different for 4WD vs 2WD. 2WD sump on a 4WD block needs a little bit of "clearancing" around the pickup point as it's right near the 2WD sump bolts - nothing a few minutes welding can't fix.
the chassis itself is identical. The cross member I do know is different however.
One of the turbos was missing the exhaust wheel! Just wondering should I buy another pair of standard turbos for $600 or what would it cost to have steel wheels put in the ones I have? Not high flowed.
Thanks for the info I'll use the sump off a spare RB20 I have.
gearbox from r33 rb25det would be ideal choice behind rb26 rwd conversion. trans tunnel can accomodate those gearbox with bit of hammer action if required. :(
I have rb20 engine mount on turbo side I think.. as well as retained rb20 throttle cable as all you need is just a custom bracket to hold it properly if the factory one didn't hold.
as long as the front pipes are from the 32 series then you can fit them no problem.
also have a spare set of 32 gtr standard turbos, very good condition. let me know if you are not going the highflow route. ;)
Has anybody tried making their own resistor pack? Its only a few resistors and possibly diodes. If anybody has a resistor pack lying around could they please test the resistance and post the results. Your held would be much appriciated as it will save me around $200 since there can only be around $30 worth of parts to make my own.
The resistor pack is $50 from the wreckers, why would u risk problems as for using rb25 box u have to get custom support brackets for the bottom half of the bellhousing otherwise u gonna chew out some boxes from flex.
  • 1 month later...
Just bolted the engine in using the rb20 mounts and rb26 sump with the diff chopped off the side. Started the motor and it ran for a few seconds and made oil pressure so I can start bolting everything back onto it cooler pipes, afm's, radiator etc
Just a few questions thou:-
Where is the power taken for the resistor pack as I had one made? I've just been running it off the battery. There isn't any power in the plug where the rest oof the wires go.
The tacho ins't working?
Also do the factory front exhaust pipes clear the power steering line (at least thats what
I think it is) on the gtst the one that sticks up behind the cross member. Tossing up the idea of buying some or making some.
Its been so far a bloody easy conversion. Only two days to get where I'm up to and I've taken heaps of photos. A mates agreed to make a web page on the conversion to kill all the myths out there.
My mates R32 GTS-T runs an RB20 stroked out to 2.2 litres and runs close to 300rwkw with a fair amount of mods....
He is still running the standard R32 GTS-T Gearbox with some specail clutch stuff going on..
Plus my car runs a standard R32 box behind a 200+ rwkw car....
Ohhhhh and there is a LJ Tonana that gets around here with an RB20det motor and standard R32 box and its modded to the hill.....(guess 350+ rwkw) The roll cage and fatts on the back are a dead give away.... (Note: the torana in question is not a legally registered car therefore no more detail will be given here)
yea i have a r32 box behind my gtr motor at 1.2 bar and it hasnt had a drama drifting and poping thrid gear.... its done about 1300ks on the track so far
i think clumsy drag racers with twin plate clutches can destroy anything on a drag strip but a r32 box hold up well for motorsport
pete
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
