Read a few of these build threads on other forums but have never tried to do one myself, but since I know a few people on this forum and see them from time to time in person I figure I may as well give it a crack.
Guess I'll start with the basics:
Height: 183cm
Weight: ~63kg
Short term goal: Hit 75kg.
Long term goal: Reach 80-85 with low body fat %.
As you can tell I'm a fairly skinny bastard. I've actually gained and maintained about 5kg since I first started going to gym, so I'm usually even skinnier. My biggest problem is self discipline, I'll go into the gym 3-4 times a week, see pretty good results and then after a month or so I'll stop going for whatever reason, usually sickness, exams or maybe a batch of assignments rock up. Basically, if I miss a week I lose all motivation and stop going.
Routine:
I'll be doing the PTC Begineer's routine for at least 3 months, then see how I'm going there. For those that don't know the routine looks like this:
Full Squat 10x3
Bench 8x3
Bent Over Rows 8x3
Stiff Leg Deadlifts 8x3
Overhead Press 8x3
Bicep Curls 8x3
This is done three times per week, with a day of rest between each session.
More info can be found here: http://ausbb.com/strength-training-power-lifting/9460-beginners-program.html
Supps and Diet:
Diet is one of my biggest weaknesses. I can be quite a fussy eater, and I don't eat much. I generally eat quite well (no junk, sugar etc), but I find it hard to force feed myself especially when I'm not hungry. When lifting I tend to eat a lot of pasta, rice, etc. I'll often make a huge batch of pasta with mince and sauce, eat that for dinner and put the rest into bowls in the fridge which I'll eat constantly over the next day or so. I also try to drink like 2Ls of full cream milk a day.
I also have like... 10kg of weight gain powder sitting in my room. The stuff is pretty cheap and tastes alright. They have a ratio of like 5:1 complex carbs to protein. I also have some creatine sitting around, I figure I may as well use as it has no major drawbacks and pretty good benefits.
Feel free to criticise my plan, I'd appreciate any feedback. I plan on starting this afternoon so wish me luck.
P.S. Ignore the hour that I'm posting this, I work nights and this is a normal hour for me. I still get 8 hours.
https://www.sau.com.au/forums/topic/369342-project-fix-lazy-skinny-bastard/
  • Replies 63
When your an ectomorph, usually increasing your calories way above your BMR is about right. I find that eating plenty of protien, moderate carbs and fat is a good start.
As for training goes, a beginner normally starts off with full body workouts so that your body is conditioned with resistance training. The best approach is to try and lift heavy as possible and always try
to improve on a weekly basis; of course you will reach peak points but your body responds best with heavy weights and compound movements.
The excerises you got listed there are a good starting emphasis for building.
Also for training your arms, try doing close grip bench press or heavy weighted dips for tricpes and for bicpes, barbell curls or heavy dumbell curls. You can even superset these exercises for greater stress on the muscles.
Oh and don't worry I work night shift too hence the time of posting this haha.
Post up your exact diet for a start as there is no point doing the program without the right diet really as you wont see the full potential of the program.
If you put in the effort you will see the gains and the beauty of the program is its simple but effective. DONT deviate from the list of exercises (unless its to change an exercise for another one as you cant do it but it still works the same muscle/s) and dont take on any advice ^^^^^^^^^^^ for working individual muscles as well unless your training to be a pretty boy with nice biceps and abs ;)
Get that diet up and go from there.
Isn't that a bit contradictory? You complimented the program which includes bicep curls, then go on to say you shouldn't listen to advice for working individual muscles?
Isolation has benefits beyond looking "pretty".
Bicep curls are purely to develop elbow health which is apparently needed to safely lift the kind of weighs this program will rapidly lead you towards.
Slight update, I only got one chance to go to the gym last week and it was pretty pathetic (I'm so damn unfit, let alone weak) so I won't bother posting up the results. I'll post tomorrow's though.
Okay so yesterday's workout:
Squat: 22.25 x 10/10/10
Bench: 20 x 8/8/8
Row: 25 x 8/8/8
SLD: 55 x 8/8/8
Overhead Press: 15 x 8/8/8
Curl: 12.5 x 8/8/8
All weights are in kilos, and I don't add the bar weigh (+~10kg). Overhead press and BB curl however I use the pre-set up bars which I assume acount for the bar's weight. Just starting light and will increase my weight each session till I reach failure. Should I max out before completing the number of reps, I'll repeat that same weight the next session with the goal of getting at least one more rep out.
Never understood why people don't include the bar weight. It's not ego stroking.
If you bench the bar with no added weights, you're not benching 0kg. Same goes for all other exercises
Laziness/ease thing for me. I don't know the exact weight of the bar (closer to 8kg I think than 10kg), but I know it'll never change, plus its one less addition to think about (I record every set as soon as I complete it).
not that hard to add 8kg/10kg to whatever final number you're adding bro.
Bench: 20 x 8/8/8
Row: 25 x 8/8/8
SLD: 55 x 8/8/8
Curl: 12.5 x 8/8/8
Add as many Tricep pushdowns/cranium crushes as curls.
Muscle imbalance is not what you'd be after and stronger tri's aid with all press movements.
But if you use the same bar, why would you bother writing down the bar weight?
I guess if you are trying to impress your mates with how much you lift, the extra 10-13kg would sound better.
2L of full cream milk a day? That's a lot of saturated fat and sugar, switch to Skim milk and remember too much calcium causes kidney stones over time so make sure you're drinking a lot of water.
Please.
Full cream milk is generally 3% fat as opposed to 1% for skim. Makes f**k all difference even if you are trying to lose weight.... and it tastes like crap and generally carries less nutritional value compared to whole milk.
Please.
Erm it's more about quantity, in 2L there is like 20g+ saturated fat and 100g+ of sugar...please
He's right, it's proper gym etiquette to include bar weight. Barbells will most likely either be 10kg or 20kg (olympic style). Have not really seen any in-betweens.
Once you get properly into it you'll start including the bar weight, because you'll start comparing yourself to what friends and other people are pressing, whether you like it or not...and inclusion of the bar is the standard. When you start plateauing, you won't need to do as many calculations and you won't even think about the weight...you'll just know it by how many plates of what physical size are on there. All becomes very habitual.
It's useful to have the total weight for calculating ratios, doing comparos and tracking progress.
Yep, that was my point... Including the bar weight is the 'industry standard' if you want to call it that. At the end of the day, you're pushing/pulling the weight of the bar in every exercise.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
