How did you find the fit of the rear over fenders? I've bought these from Viva already, wondering how much extra work is in yours thanks.
Well we haven't moulded them on yet, but they seemed to line up pretty good, the only thing extra we are doing is a bit of trimming to stop sideskirts hitting (not viva's issue), and extend the fibreglass that goes around the fuel cap, if u know what im talking about.
what are you gunna have to do to get the rear wheels under and fitting nicely? do the fronts have any scrub issues?
loving the build mate!
as soon as im back in australia after my stint in london im keen to start a build..
the hardest bit is deciding what car to start with. s13 or 14, 32 or 33, or just buy a gtr and tidy it up. argh!!
good luck mate.
cheers adam
good luck mate.
cheers adam
hey mate, prob just a bit of camber, the rims will still stick out a little but thats what im going for. we had a little bit of scrubbing on the front bar from the front tyres but thats all sorted now, just had to push the bar a little forward.
If i was picking out of those 4 cars, obviously i went the 32 first, my next build is going to be a 34. but if not i would go an s14. Good luck!
rear guards are trimmed, over fenders refitted and drove it about 15km to the painters place, now just paint to go for the body, then new coilovers, camber arms and toe arms cheers.gif
hey jum its your old mate damo cars looking good man love the stretch tuff as hell give me a yell when its done and you goin to eastern creek ill try to be there should look mint when its done may have something by then to give you a run
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
    • Is the problem that we just disconnected the line, does it need to be plugged? I’d rather not buy another master cylinder
    • Clutch is same same. Tailshaft is not. Diff will drop in. Half-shafts will not mate up (5x1 on turbo, 3x2 on NA). There is also the strong possibility that your auto NA gets its speed signal from the sensor on the diff, not the gearbag, and that will leave you without a speedo. You can do all this, you just have to do a lot more than you thought.
