Jonno is correct, just remember you can top a sealant with a wax but you CANT top a wax with a sealant as sealants need to bond tou your paint and can onyl be layered if done within a flash time say 10-15 min depending on the product.
the mothers cleaner wax can be thrown in the bin its no good, use the AG SRP (super resin polish) as step 4 applied via hand is fine. I would reccomend a product called Prima Banna Gloss though instead, this is a glaze with carnauba in it also and is fantatic at hiding swirls as per Prima Amigo. see here keep in mind they will come back as they are filled not removed but makes a big difference. http://www.detailpar...iewtopic&t=3447 see the difference.
Then you can top that with a wax not a sealant, such as DP max wax or another wax you have.
I reccomend STRONGLY Naviwax IONCOAT from ebay.co.uk it last ages and looks great if you use bannana gloss and top with that it will appear swirls free for ages! if you use a cheap wax that doesnt last long it means its wears off and then the bannagloss will also as it wont be "held in".
Regards,
Mitch
Ps as Jonno said I strongly reccomend checking out www.bowdensown.com.au and www.waxit.com.au Support the people that support you.
mitch for the sealant i use (FI Seal) - apparently it needs a 72 hour minimum "curing time" period before applying another layer wacko.gif
Thanks for clearing that up. I think the nice finish I got was probably from Mother's Top Coat (glossy and water will dribble down). I wonder if that thing works like wax (helps protect from weather). If not I'll have to drop by Autobarn tomorrow and grab a wax. Any recommendation for off the shelf wax? I really wanna get it done tomorrow. ZZzzzz.
im not too familiar with many off the shelf products besides meguiars and turtlewax myself, but the water "dribbling down" or beading sounds like the effects of a wax to me!
if you haven't put a sealant down i found meguiars tech wax to work very well, however this does have cleaners in it which would remove sealant.
Yea I read on the Mother forum that the Top Coat is the final touch to the detail process and you dont need to add anything else on top of it. I'm thinking of using the cleaner carnauba prior to that though. And guess what? It looks like its gonna rain! Maybe I should do it another day...
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
