  • 3 weeks later...
  • Replies 204
Great job on the build. Very impressive. Can I ask a few questions?
What did you do with the bottom 4 bolts on the gearbox that bolt to the Sump (as the sump is now lower with the adaptor and the bolt holes don't line up?
Did you have any issues with the Power steering line that enters in the middle of the rack directly under the sump?
Do you have any pics of the Clutch master solution? and how do you find the pedal feel?
Thanks for the praise.
we drilled out and tapped two of the holes that we could make work and put factory bolts in. the other two holes require welding to build a area.
It is close but still half a fingers gap away from it. there is a bolt on the sump thats close to rack on passenger side we just ground the head down for extra headroom. the engine twists away from it anyway.
I can get pictures of the setup. basically its just a plate that you bolt to the firewall with bolt and nut, then two holes tapped out that bolt the stock cylinder too. Made up a new clutch rod too. The pedal feel is no different, we suspect that the booster never worked in the first place but it is no different to any other car with a multiplate clutch in it.
If your doing the conversion and have a stock plenum you might not have any issues just the hypertune manifold is alot larger he standard
Many thanks for the info. I'm doing a similar thing with a MP III R34 GTR. (I think yours is MPII)
Here is a pic of the car and the old 2.8 engine....
I had the engine all assembled, but I am using a dry sump kit. It looks like the dry sump kit is lower than the wet sump by maybe 20mm.... so she not looking like she is going to fit. Here is a pic of the engine bay and a pic of the engine sitting on the power steering line... argghhhh.
I'm also running a Greddy Intake so have the same issue as you with the clutch booster.
It would be great if you could post some pics of the booster mod. Also, the "other two bolts" did you put a thread in the sump holes you made, or did you cut down the back of the sump to make a flat area and use bolts and nuts?
Edited by TwinTurboCelica
Awesome looking car.
Its Tims car the orginal poster hes just very lazy at posting updates so i took over. Its MP2 yeh.
how come your getting rid of the 2.8??
The sump is a stock sump with the front section cut out and remade so we dont have any issues there. how much is it hitting/clearing by? Is the engine sitting on mounts in that photo?
Your in luck cause the clutch master bracket is coming out in next week or so to get finished and cleaned up now that we know it works. so i can take photos and send them too you
2 holes that we could we tapped thread into and found right length bolts, and i think we cut some of the cast bracing away and bolt and nut. Welding the sump for extra material would make for a neater solution but nobody sees it under there
Edited by nick81xd
Again, thanks for the reply.
I didn't get rid of the 2.8 ltr through choice, it threw a leg out of bed and smashed the block and the sump to pieces (think 3 seperate holes you could put your hand through). It was running 760ps and 1.7bar at the time.
The 26/30 option looked to be the best replacement as I needed to replace the whole bottom end.
The engine mount was not sitting 100% down. one side still had about 10mm to go.
Best case, the pipe needs to be relocated and the cross memeber cut and modified. Worse case it just will not fit. I'm thinking the dry sump may have to go, but I'm not 100% happy about that as the car will see the track on a regular basis, and the dry sump was a major consideration for the build.
ouch about the engine. at least you finished it off in a spectacular way. The old 2.7 in tims car(owner) wasnt changed by choice either. Part let go at 9960rpm and a mess followed.
Its a crude option but you could "relief" the sump around the pipe and also bend the pipe down a little. last resort option of course.
I would be definetly be trying to keep the dry sump its good insurance.
Well due to work commitments and the turbo oil drain ripping and not havin resources to fix in time powerplay is a no go for the car :(.
Have to aim for the may powerplay. Should be finished tested and tuned by then. Begging for a thrashing.
i think i saw some lilly white chicken legs sticking out from under this thing on the weekend, does that mean its turbo drain is all speedflowed and ready to hit the dyno at gladdy on sunday?
Edited by TheGotoGuy
Hasnt been tuned yet, has barely been driven. Work commitments have really prevented any progress on it. Hopefully in the coming weeks. It will go for power tune and see what boost its happy running.
Car is loving the new engine. Its so much easier to drive and more user friendly Tim (owner) is saying. Evident by the lack of throttle percentage being used.
Had the sniffer in the exhaust aswell. around town cruise its only a little bit rich but under full power its going to 10.1 afrs so heaps of power left in it. Goes in soon to get a tune done.
Tidying up engine bay now finish off a few bits and peices, then its ready to go to powerplay hopefully in january.
Took it out for a thrashing on the weekend and aside from banging limiter too quickly its awesome fun.
photos and videos
Looks fantastic, great thread - thanks for sharing the build.
No way... You bought your 34 from global auto through edward lee's right? Saw this car on youtube and It sounded absolutely mental
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
