APHID:
what intake manifold are you running? we are going to have issues with the clutch master fouling on the hypertune intake so we are trying to get around that.
we have to run the spacers unfortunetly due to bigger the factory sump we have no clearance to play with.
Yeah I still run the stock intake
  • Replies 204
oh well we cant be that lucky. thanks for the help you might be getting a pm or 3 depending on how nice the car wants to be
Car Update
Should be able to start assembling bottom end thursday arvo, have to put one cylinder together and do some measurements to work out the comp ratio so we can choose appropriate head gasket and if we need to machine some off the tops of pistons.
Head is getting there, getting it back in next day or 2 to finish the port matching and then it can go for final clean and then assembly.
Starting to get to exciting bits of build.
Plan is for a short time from building engine to start up to tuning....then results we are aiming for :D:D
Your better off not skimming the tops off pistons to achieve the desired deck. You compromise the piston strength and risk upsetting the balance. The last engine saw this done to ended badly with the crown giving way at 8000 RPM. This was followed by the rod seperating from the piston so it could make some holes in the block. It destroyed everything bar the intake and exhaust manifolds.
If you have only had the top of the block leveled to the centerline of the crank, the top of the block will have only been shaved a 5 thou at most. This means that with a 32mm compression height flat top RB30 piston, the crowns will be at most 5 thou positive which is perfectly acceptable.
Don't be afraid to run a positive deck. The closer your crowns are to the quench pads on the head the better the efficiency of the engine. You can safely go as close as about 36 thou, provided you measure everything very very carefully and your main and rod clearences aren't more than about 2.5 thou.
Edited by GTRNUR
it was a last resort option. Really dont want to mess with pistons thats for sure.
the bottom end was brought with a measured around 10:1 compression so we are looking at anyway to drop that so we can put some boost into it to make use of T51R
The average head after machining comes out between 62-63cc. Call that 63.
An RB30 with the typical RB3025 CP flat tops and a 0 deck and a 1.2mm head gasket has a CR of 8.2:1.
5cc domes gets you 8.8:1.
14cc domes (RB26 size), gets you 10:1.
What pistons have you bought for this project? You either have the wrong pistons and have over-trimmed the deck of the block to achieve a 0 deck, or your maths is a little wonkey...
If you can give me all your dimensions I can plug them into my engine calculator and give you some options if you like?
thats what we were told it was, we havent measured it yet as we are waiting for bearings to dummy fit it all to get accurate measurements. Hoping they measured wrong thats for sure
what measurements you need? by end of the week i should be able to get them all.
Pistons im not sure exactly but tim should be able to say that. hope not the wrong ones cause really wanna get a start on engine.
Thanks heaps for your help. Any help we can get is awesome
Edited by nick81xd
At a glance you can tell if the pistons are flat tops or domes. If they are dished they are probably RB30ET pistons, and are not suitable for your application.
I've attached a copy of a spreadsheet that will get you 1/2 way there with the calculations. You need to fill in all the red values to produce valid data.
GTR engine-calc.xls
i remember this car for ale a while back, my uncle almot bought it but would have had too many dramas with the top mount and manifold ect being from melbourne, i remember he told me to make up my mind as there wa a guy from queensland wanting to part trade his hsv for it.
what a beautiful car it is though mate, i still have all the pictures he sent to me, just out of curiosity though if you dont mind me asking, how did the engine damage?
becaue i remember it wa a top dollar job at croydon and it didnt have many k's on the rebuild.
either way, nice build thread
That means your in custom piston terrirory if you want to lower the CR. Its easy enough to sort out though. Just order an RB26 design with the appropriately sized dome to match the CR you want. The spreadsheet above will calculate that for you. Quantum Racing are the people to contact.
Steve Brown
Sales Representative
Quantum Racing Industries
Unit 15, 157 North Road
Woodridge, QLD. 4114
Australia
Ph: +61 (7) 3290-5911 Fax: +61 (7) 3290-5933
Web: www.qri.biz
The alternative and less desirable solution would be to run a 2mm gasket along with deleting one of the quench pads in the head. That would achieve a 9.0-9.2:1 CR, but also creates a slower and less efficent burn in the combustion chamber, along with a poor burn zone in the remaining quench pad area. Fine for high boost, but not good for response or economy.
was nothing to do with the build or croyden it was me being a bit harsh on it.yeah thats me i used my ve clubby as a holding deposit on it.was what i had always wanted so i had to have it.
UPDATE:.
Block is ready for final assembly after a very light clean up hone of bores from sitting. Crank got polished aswell
All rods have been balanced within 1gram for a smoother engine.
Dummy fitted crank and one cylinder assembly to measure deck height etc to work out compression.
Had 1mm machined off the tops of pistons as it was around 9.5:1 comp and we all know that isnt pump fuel friendly.
Currently deciding which head gasket to go with, we have two options of 8.7:1 or 8.9:1 compression ratios each have pro's and cons.
Need a set of ARP main studs and we can assemble the bottom end finally.
FINALLY SOME ACTUAL PROGRESS.
95% of the part we need to finish engine off are here so today got stuck into bottom end.
So good to see some results after so much measuring and planning which hopefully pays off by having a reliable fun engine.
Measured up ring gaps and they were just about perfect for the high performance engine specs so didnt need to ring file them.
Plastigauge the mains and big ends and they were also spot on with advice from engine centre.
ARGO rods and CP pistons
Some building.
Head wrapped up ready to go on. Ported and polished, 280 degree cams, Ferrera valves, JUN valve locks retainers and springs.,...cant wait to hear the lumpy idle again
Cometic 1.8mm head gasket
had to finish off the pick up for the sump adapter mount hole and measure the height it needs to be welding, which is getting done tommorrow.
need some head gasket dowels cause they went missing and finish drilling the oil restrictors then we can put the head on and get to work on accesories fitting.
Then comes another challenge...getting the thing to fit in nicely
BOTTOM END OFFICALLY FINISHED
Pre planning and a few minutes of frantic bolt placing and tightening, we managed to get the sump and adapter glued and on. Pretty confident its not going to leak......fun job of cleaning all the excess when it dries sucks though.
Have a hiccup with the oil restrictor for the head not being able to drill through a grub screw sucessfully so we are back to drawing board for the temporarly. Thats all thats holding us up from bolting head on.
Nitto pump full of vasoline to help oil pressure on start up.
Oil pick up welded and bolted down
bottom end closed up hope to never see it again.
PROENGINES sump adapter kit is a awesome kit and suggest it to anyone wanting to do a 4wd RB30 makes life alot easier
how are you doing it?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
