i have a s1 stagea motor in my 33 and you could NOT use the RWD pickup. the RWD pickup point is there but it's blanked out and the oil gallery only goes to the AWD pickup point anyway
it is exactly the same as a 26 block
i just used the stagea sump and had the 4wd diff cut off and the welded up.
It depends on EXACTLY what you are trying to achieve.
Keeping 4WD? I assume not
You have not been descriptive at all about what you want. With an adaptor plate, you can bolt the tin sump to the stagea block and just make a custom pickup which is easy to do.
