So yeah, R33 with RB25DET. Standard fare of broken exhaust manifold studs- 2 of them, 1st n last ones, pretty generic :closedeyes:
The thing is i dont have any problems with the seal of the manifold. Though Im about to put another turbo on (HKS 2535) and wondering if this is a job that should be done prior to installing the turbo, or is it something that is likely not to really give me any trouble?. Obviously it would be a bitch of a thing to install the turbo n then have to pull it all off again to do studs cos i got a manifold leak....
Honestly im busy enough at so that rules out doing it myself (ill be doing the turbo install n thats my time budget blown). N its a pretty riduclous cost to have a mechanic do it- n i then might as well get him to do the turbo install at the same time = much more money again.
thoughts n experience people??
cheers
https://www.sau.com.au/forums/topic/369371-broken-exhaust-manifold-studs/
ok cheers for that people. Will definately do it then...
just to confirm based on my recent research- RB25DET studs arent too bad to get out yeah? basically you can get the manifold off and counter lock 2 nuts on the end of the broken stud and extract that way?. Or weld a nut on the end to grab onto?
Its just that i went to a mechanic about this a while back (non import mechanic) n he was saying it is highly possible that it might require the stud being drilled out and a thread rebored into the block. Which as you can imagine = $$$$$$$$$$$$$
any indication of whether this ever ends up being the scenario?
5 of mine broke in trying to get them out..you can drill them out ,in fact you probably have to, but the thread shouldnt need to rebored unless its drilled by a butcher
If you soak the thread in wd40 overnight a couple times, it should loosen up enough to lock 2 nuts on and wind it out. Remember the head is alloy so it shouldn't weld itself in like with cast iron or whatevs.
Certainly preferable than attempting easy-outs etc.
After that, give the new studs a wipe of anti-seize compound.
I dont think it has anything to do with the nuts welding themselves into the head. As the manifold gets hot because of its long design it twists, this puts excess stress on the studs and they must either fracture or just get weak in the middle causing them to snap when you try to remove them..I doubt wd40 can solve this problem but you can try..
lets not forget you studs are now 15+ yrs old, time, heat and load would most likely be the cause, i had a couple of broken and when i pulled the manifold off broke a couple more, all up had 5 broken, none needed to be drilled and helicoiled, replaced all of them so i should not have to worry about them for the next 15 yrs :)
definately do it this time, there must be a knack to it the thread doctor had mine out in about 20 mins, try to find someone in perth who is mobile or if need be take the head to someone.
workshops can make money on getting him to do it. Make money doing what they do whilst car sits there gettin fixed by thread doctor.
Thread doctor charges $130
Workshop charges customer $150
I have just picked up my manifold studs, washers & Nuts today
Had 5 snappped, got 4 out, one to go, being a real C***. Just drilled and Easy out.
Edited by bluey33
yyup.. i knw the feeling.. im a mechanic and i have the tools, skills and ability to do the thread removal but i would much rather pay a thread guy to do it while i get on with something else.. they do this shit for a living and it takes them next to no time where as i would waste an hour or three doing all of them if they are snapped below the head surface,
not sure if this info is too late for you, but seeing as you are in perth, you could give this guy a try.
his prices are quite competitive, and has a good reputation on another perth import forum, AL.
Galvsport - Mechanical maintinence and upgrades
0402648544
Josh.
I do these myself by:
1) Removing the manifold and other obstructions in the engine bay
2) Use a center punch to carefully mark the center of the stud with a hammer
3) Use a small drill with a 1/8" or so titanim bit and CAREFULLY, SLOWLY and STEADILY drill completely through(about 3/8" distance) the center of the stud. Make sure bit is aligned and is center. AVOID breaking bit and its ok if the hole is slightly off.
4) Use a slightly larger diameter bit and drill about half way or more(same rule as above)
5) Carefully use the largest diameter stud remover that will hold(one like drillbit that locks by turning anti clockwise)with hand turn. Stud should turn out.
6) Cleanup and replace. Old non-broken studs can be replaced also using two nuts to lock and turn out.
Hope it helps..
lol I am surprised that people even ask these questions.
If a wheel stud breaks, do you just change the rim and leave it till later?
no but id say a really high proportion of skylines get around with a couple of broken manifold studs with no problems at all. hence the question whether i can just continue with this status quo.
I dont think many skylines, or cars, get around with a broken wheel stud. anybody could realise that this is likely to fail due to the obvious forces put on it and that when failure occurs its going to be ugly. Both conditions that arent present in the head stud issue.
Interesting analogy though.....:glare:
Edited by jjman
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
