Hey guys,
Thought the Motorsport section would be the best place to ask about how to read the numbers on our coilover springs.
As some of you know our car is a Circuit car and we are wondering if from the rough deciphering of the numbers printed on our springs if they are too stiff for the circuit?
Are we correct with what the numbers mean below (we've emailed Merwede in Holland but have had no reply yet)
Merwede front Springs read - (25 250 59 118) = 250mm length, 59mm ID, 11.8kg/mm (dunno what the first 25 is)
Merwede rear Springs read - (250 49 98) = 250mm length, 49mm ID, 9.8kg/mm
If we're correct with the fronts being 11.8kg/mm and the rears being 9.8kg/mm are these far too stiff?
Who would you guys recommend as a good softer spring to buy and what rates would be ideal for the circuit?
Currently we run HKS Hipermax III coilovers, Dunlop 240/625R17 slicks and Ikeya adjustable arms...
Front springs they read '25 250 59 118' and are Merwede
Rear springs , read 'Merwede Progressive 250 49 98'
there's no standard, each manuacturer writes whatever they want on their spring. eg my Swift springs have Swift 070 or similar on them. That's a 7kg spring. My King Springs have thier part number and rate in lb written on them.
any decent/proper suspension shop that specialises in race cars (not franchises) will probably have a test rig to measure the rates. or for linear rate springs, there is a formula you can use to calculate the spring rate - google "spring rate formula"
irrespective of what rates they are, you probably don't want a progressive rate spring in a circuit car.
Edited by hrd-hr30
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
