1978 Nissan Skyline (Naps)
post-84213-0-55608400-1309333759_thumb.jpgHi Guys, '
Just logged onto this website and was wondering if anyone knows about the NAPS and how rare are they, haven't seen another one in Melbourne. Peter.
Edited by Peter C
Nissan Anti Pollution System.
I don't know much else but will call my mate Mario to come on here, he knows everything about this model.
Edit: You have the same louvres as me! Legend
Edited by Socrates
Was also on the Californian 280zx. It's just a system of fuel injection and exhaust recirculation to lower gas emissions. Not many around, as the Bosch L-jetronic got upgraded and passed the emissions testing. I've seen it on a L20A in a C210, pretty interesting, no power upgrade though
Hi Peter,
My c210 has the NAPS, Badge, its what socrates said, its to do woth the anti pollution systems in Japan
back in the seventies.... My coupe is a JDM,...import, also where abouts are you in Melbourne mate, love to see your car,
im in the western suburbs..
Im sure if you need advice or other things we members here are happy to help if we can..
Its good to have you here,
Cheers
Mario.
Thanks for the info Guys. I used to use this car as my work car for 10 years as you know the rust creeps in and so am in the process of replacing panels and getting a paint job. Currently running a 2.8 but I have a hot 2.6Z engine in the shed that I am thinking of ratting the best bits from.There seems to have been alot of features on these cars for their age air con,power steering,electric windows,closer ratio 5 speed gear box. I'll post some photos when I have it done.
Thanks Again.
I think this model, not the JDM model, was what started my love affair with all things Datsun/ Nissan. I remember reading about a tweaked model called "Alpine" in the SMH, but it was not till 1984 that I got my first RMR30 Ti My daily is still anR30..
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
