Im in need of some help,
Had an issue a few weeks ago when the belt for the air con unit was fraying, so i ordered a new one. In the meantime my mechanic removed the faulty belt. That meant that my air con was just blowing air, but not cooled. Then it started to only blow air if put on full power. I assumed this was because of the belt missig. Anyway today i had it replaced, but STILL no air in 1,2,3 only on 4. But the air con is working, as it is now cool air, but only at full power.
Any suggestions?I tried changing the mode to feet or windscreen , but still nothing....
Any help is greatly appreciated
thanx
Will
https://www.sau.com.au/forums/topic/36941-r32-air-con-issues/
I know when u click up to 4, u hear like a relay switch so the fans can get more power.
and click off on 1,2 or 3. U might have a broken circuit to lowere power fan circuit or something. Dont realy know, just an observation made oneday playing around with mine.
most relay's on cars are in a little black plastic box. probably best way to find is turn it from 4 and 1 2 3 and 4, so you hear the realay. And try and find it thatway.
Also mayb worth haveing a look @ the r32 GTR manaual u can download atm. IT should have something in there to help ya.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
