Hi,
I am selling my Honda Prelude, i have recently bought a house and need the extra money.
-1997 Honda Prelude Vti-R ATTS (Active Torque Transfer System-LSD)
-White
-90,000Km
-Photo's can be e-mailed if you are interested
-Located in Sydney
The car has the following modifications:
Full factory Honda body kit(including wing on bonnet, very rare)
AEM adjustable cam gears
AEM light weight pulley kit
Neuspeed short shifter
Neuspeed sport springs (1.7" drop)
OBX 4-2-1 stainless steel extractors
Stainless steel dual tip rear muffler (no exhaust drone at all)
Magnecor KV85 ignition leads(made in U.S.A not Aust.)
JUN ultra light weight flywheel (5kg, factory flywheel is 10kg!)
Daikin sports clutch (not brass button)
Falken Azenis ST-115 tyres on the front
The car has been dynoed to tune the adjustable cam gears and makes 108Kw at the wheels. I have the dyno sheet for proof. It was tuned by Croydon Racing in Silverwater, so you’re guaranteed the car has been tuned perfectly. It is an ATTS model so it has an active LSD unlike a standard prelude. This is a fast car for what it is and is very nice to drive.
I have spent a lot of money on the car (parts & labour) most of these parts where imported by me from the U.S.A and a very expensive. All parts were professionally fitted.
I am looking for offers above $24,000.(will now consider offers over $22,000) If you are SERIOUS call me and will discuss the price.
This car is much cheaper to insure than a turbo car. For any of you younger drivers out there wanting to buy a good performance car with out the 'turbo' insurance premium you may want to consider this car.
If you would like to ask any questions or arrange to see the car, e-mail me or you can call me on 0431 064 288.
Thanks.
e-mail address [email protected]
This is an immaculate, car, ive been in it plenty of times, whoever buys it will be a very happy person :)
And although we are used to figures like 160+rwkw on this forum, trust me, although this car has comparably less, it still goes very well, its a lighter car.
  • 3 weeks later...
Very nice prelude, 108kw at the wheels huh. SO your saying that it would keep up with, or be infront of an Integra typeR ?
Throw some nice rims on it and it would be even better. Good luck with the sale..
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
