from my memory of taking out my old steering rack, it was pretty simple.
i highly reccomend using a hoist for this as its just so much more easier.
12 mm bolts using i think it was U clamps for holding it in place
undo the fluid lines *make sure to have something to catch the liquid in, the bigger the better*
undo the spline to the steering wheel, *key tip is to have steering wheel straight b4 starting this, makes it much easier, unless you have a bosskit etc then it doesnt matter so much*
undo the nuts for the tie end rods where the knuckle joint is.
then make sure the spline comes off the steering wheel shaft then remove with some jimmying and twisting oh and patience.
if u look at the spline there is a groove so it only fits in a certain way. *i made this mistake when i put it it b4 checking and was fartarsing around untill i found out why*
then basically do the reverse.
spline back on the steering wheel shaft.
lines back in.
all bolted up.
double check everything.
top up with correct fluid.
start car and turn steering wheel lock to lock to bleed system and top up if required.
double check for leaks.
take car for a little drive to find the middle, and adjust if necessary if you have a boss kit.
a re-alignment is highly recommended.
this is all i can remember and i hope it helps, and if i have said something wrong or missed something someone please correct me.
cheers aaron
lines back in.
all bolted up.
cheers aaron
AS above but soak everything in wd40 or 5.56crc before even starting it.
  • 4 years later...
Thread revival, about to do this on my R34, old rack's been leaking for ages.
I've got an OEM replacement with around 80,000 kms on it.
I'm assuming the above instructions will be pretty much the same for an R34, can someone please confirm?
Can this be done on jack stands i.e. without a hoist?
Also is there anything else I should look at doing whilst the rack is out? What's the best way to check the condition of tie rod ends inner/outer?
I've got new rack bushes to go in with it.
Thanks guys!
Can be done on jackstands. Give all the bushes a look over while you are under there. If any of the boots are split its time to replace them. It's pretty straightforward, just time consuming. I recommend putting on beers and getting some mates over.
  • Like 1
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
