hi guys looking for some opinions to help me make a decishion i have loved skylines for year and at the end of this year i will finally be able to get my first skyline but only an N/a due to restrictions on licencing do i start off with an na and build my way up doing suspenshion mods and minor perfomance or wait and get a factory turbo
TLDR p plate na modify and convert will i be disapoint with result?
https://www.sau.com.au/forums/topic/369474-na-to-turbo-heart-break-or-hero/
NA skylines defs not worth it, i have one and kinda regret it, always wanting more power out of it wish i could have a turbo and run boost and keep increasing boost! i recommend if it's not urgent, get a R32 GTR or a R34 GTT and mod it up in your garage, strip it again and again understand it more, then once u hit your fulls just drive it everywhere knowing the car u know and understand inside and outside!
hey mate years ago i bought a n/a from a deakership, but after purchusing i was informed that the n/a block wouldnt support a turbo even though they are same block....not sure if its a myth maybe u should think about doin what grey said or buy the n/a and buying gtst front cut to installl in it later
Have a chat to Aggroman (Dave). He took his NA 34 and when he got off his P's he did a turbo conversion with great results. Mind you, he's an absolute wiz with a wrench but worth have'n a chat to him.
due to the different compression between the turb and na engine to turbo it you would have to change the pistons to turbo ones. Ive read that you can use the n/a pistons but you can only boost it to the bare min.
I am in this situation too. i am throwing up doing a rb25det swap into my 32, a rb20det swap or just selling the car and buying a turbo after i get off my P's.
I am leaning towards selling it as its alot of work to get the N/a up to the same level as a stock standard turbo.
if i were you i would hold off and just buy a turbo, when they say N/a skylines are slow THEY MEAN IT !! haha
Half the na section is on this topic, and of the hundreds of people on here who have done the na+t conversion I have only read of very few who haven't regretted it after a few years. IF you're going to do all the work yourself it won't be too dramatically expensive, but it's still wasted money and effort compared to buying a factory turbo skyline. And it's no small job, the easiest option is to put an rb25det in the car and that involves changing the ecu (and wiring loom i believe?).
Also STRONGLY recommend a defensive drivers course if you're going to be driving a rwd with no traction control. There's really no downside to learning more techniques about safe driving, and you may have seen that there's plenty of accident damage on sau. It might seem like a waste of time to some people, but sometimes a split second is all you have in an emergency and if you don't react properly you could be wishing you'd taken that driving course while getting your car towed away... Or maybe just hoping you'll be able to walk again one day.
I didnt bother reading it all and CBF writing a massive essay so ill break it down
It can be done, its not hard at all
manifolds bolt up fine, dont need to change pistions thats crap.. Plenty of cars run 10:1 Comp
GTT aftermarket ECU's work, I run A PFC in mine. (secret quirrel trick to get rid of engine check light as GT's dont have traction control, dont know what that is? google it. Its what the stagea ppl do as they have hte same problem any good workshop cna do it). You can also run standard ECU with a piggyback to handle fuel etc like a Greddy Emanage Ultimate with the Ignition Harness thats sold seperately (required for r34 only)
The only parts that you cant get off the shelf are turbo water/oil lines they need to be custom (easy as) everything else matches up fine. except for a plazmaman plenum you will need GTT runners
So long as you have enough exhaust flow boost isnt an issue, Im pushing 250KW atm with standard motor, highflow turbo (at 14psi) and supporting mods and will be up to 300-350 with a turbo change.
Budget 4-5K if you are going to give it to a workshop to install and tune. Parts will set you back roughly 3.5K depending on computer choice.
The 25DE Neo motors are tough as nails so dont worry about throwing a rod unless you service your car poorly..
Wanna see how one goes? Come to the Texi in September and watch me..Or just look at my sig below :P
Do it.
Check out these two threads, might help you decide:
http://www.skylinesaustralia.com/forums/topic/33407-how-to-turbo-your-na/
http://www.skylinesaustralia.com/forums/topic/249186-nat-power-results-na-t-turbo-conversions-only/
I've done the same thing, and am very happy with the results.
Started out with a stock car, did all the suspension work, put in a good stereo which is a bit more of a hobby than anything, and heaps of other little bits and bobs along the way. Started prepping the car for the turbo conversion, decent wide tyres, adjustable bushes for good alignment, coils and plugs, changed all the filters etc. At that stage, it was a good fun car to drive, handled well and a good daily, just low power and a crap sound...
Did the conversion, ended up costing me around the $2k mark parts alone as i did all the work myself, apart from the $600 of that being custom intercooler piping to avoid cutting the engine bay at all.
Just got the exhaust done, fitted a boost controller (currently set to nothing until I can get the car on a dyno. Currently, the car's even/above par with a mates GTST on 10psi in terms of acceleration, having the turbo spool at 1500rpm, and now 5psi at 2200rpm is very street able.
You'll get alot of negative feed-back against this path, yet the only real downside is the 4 stud brakes/wheels, and the gearbox (depending on the car) that will hold you back. Realistically, not alot of GTST's have standard anything anymore, so why not do the basics while on your P's, and the power package later on?
No, it's not legal to convert it/drive it without an engineers certificate, yet neither is a GTST with a boost controller, FMIC, loud exhaust etc. etc.
WYTSKY DID hit the 295aw/kw mark, then de-tuned for safety, as Aggroman said, 250kw on 14psi, it's not like the engine is limited to any less that a low compression motor, PROVIDED you don't try to make 400hp out of $50, which applies for any performance car...
I think i'll shut up now... :whistling:
Biggest thing about turbo motors and high compression is to keep the boost at a reasonable level. Low compression on turbo motors is to ensure there is no detonation.
As others have said high compression turbo motors will be more responsive up to a reasonable boost level and then detonation risk will prevent you from making more power.
So good fuel and good tune will keep you sorted.
+1
Realistically, it's not that much more expensive to get good DET power out of a DE+T, yet with more response and the power moved a bit to the left.
There are options to oppose detonation at higher boost levels. E85, decent inter-cooler, water-meth injection, but reliability, long-term effectiveness and cost are the factors.
mine lasted 1 year lol
crack the ringlands on piston #6, ran 1bar of boost.
but liek others have said, aggroman & wytsky have been running decent power on theirs with no issues.
1 bar is a fair bit through 10:1 compression, and a year isn't bad on an un-opened motor, but I bet you didn't regret a moment when it did go?
WYTSKY is running ~19psi from memory?
which make/model do you think of when i say UTE?
SS ute? xr ute? hilux?
so why not use the same principal when choosing a n/a car?
for me its honda integra/civic type r/s2000. not a skyline.
your re-sale will be much much better. when you're ready for a turbo car then go for a skyline. its not worth the $ converting if you cant do it yourself (brakes/rotors, ecu/tune, injectors/pump etc etc). its definitely not a case of just fitting a turbo and off you go.
thanks for all the replies guys it has given me alot of fuel for thought im hoping for an r34 thats the dream i can do the work myself borrow people garages :) as i dont have my own. really want a skyline love them to bits but i really dont want to be disapoint with the na and i do understand the amount of work ide be getting my self into goal, is about 220 as a daily, conservative i know but i dont wana break my babby .can i have recomendations for an na car ? thinkin about getin a mr2 ?? as theres one going cheapish in my area " lookin to get into the drift scene :)" as for commin to the texi i would love to sexy skylines every where sounds like a day in heaven
btw agroman that would be sick i love 34s yours looks mint man absouletly mint can i please have a ride shot gun ??? please???
dude if u wanna drift DONT buy a mr2. Na s13 would be the go + u can always turbo the s13 later. my self i wouldnt bother with a na platform, unless u willing to spend sum cash, ie, they all get smaller brakes, smaller gearboxs, shit diffs etc.
NA MR2s are slower than a wet week, and any mid-engined car is a pain in the backside to maintain. They look cool, though.
Nothing wrong with a DE+T as long as you're not chasing big power/boost. NA internals won't ultimately be able to handle the same cylinder pressures as FI ones (even taking the compression ratio out of the equation) but, as above, you'll still be making a fair amount of power before that becomes an issue. At the same time the lower weight internals and higher compression is going to improve efficiency and response.
Personally I'm all for a DE+T on a street car. On the street big power isn't usable that often, but being more fuel efficient and more responsive is something you can appreciate every day. If you're going to sink big bucks into it down the line to chase big power, even a stock DET is going to need to be cracked and brakes are going to require upgrades, so starting from a NA position becomes irrelevant.
As people have said, it is a good path to work through. Start NA and work on supporting mods (handling, driveline) so you can get used to the car and how to drive it, as well as prepping it for a big power increase, and do that last.
I had a MR2 that was built the other way (stock open diff, rubbish D2 coilovers, stock brakes, but big power) and the thing was exhilarating when you punched the throttle, but scary (in a bad way) when you tried to stop or turn. It's not something I care to repeat.
  • 1 month later...
what about an actual engine transplant my na r34 already has the gt-t brakes so all i would need is the drivetrain of a GT-T (when my one snaps lol ) i can get an NEO rb25det (including ecu, loom) for around $2000-2500 bucks im just wondering what else needs to be done?
i know buying a GT-T is a better option but i would like to work on an engine and learn how it works before i put it in my car (itll be out for around 2.5 years so hopefully i can mod it whislt its out of the car) then when im on my fulls bang it in.
Cheers,
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
