I agree. I love the black leather & electric seats, but the switch gears digs into my thigh a bit on longer trips.
There is a Nissan service bulletin that covers a (potential) fix for this - I posted them on m35.info forum - but I've still not bothered to try it.
  • 4 years later...
Bit of an old thread, but does anyone still do the English conversion for the stereo ? Have just imported an 04 ARX, replaced the suspension with mca x-r's and bushes are up next before it goes for a blue slip.. But the stereo is the next priority after that.. I'm in Sydney if that is relevant.
Many thanks in advance
Ps has anyone been able to get the maps working for Australia ? Not overly important, but curious all the same
I've never seen that second pocket! Mine has a weird Panasonic DVD drive in there for the GPS system.. that'll get ripped out eventually :P
I got it from yahoo auctions in Japan. Yours may have had the screen from factory as mine had the dvd rom in that area.
Problems
Turbo Failure:
If the oil lines get blocked, yes your turbo will fail. Clean or replace your lines and your good to go. Drilling your banjo's to 3mm will just cause excessive flow  and encourage oil to leak out the turbine oil ring causing smoke.
The main failure is the ceramic turbine breaking off the turbine shaft. Oil flow is not related to this. The cause is directly related to turbine speed. If you want the OEM turbo charger to last, don't put a dump pipe or exhaust on it, Don't increase boost otherwise it will fail eventually.
Rear Shocks:
Upper Mounts will rip out of the car when performance shocks are installed or even with OEM. The top hats rust out due to the stupid design
Rust:
They like to rust in the lower kick panel, window frames, gearbox mount point.
Air Flow Meters:
The OEM Airflow meters blow continuously. Best by a AFM off ScottyM35 as these are the only ones Ive seen last.. better than getting stuck..buy one straight up
Interior:
The interior is just ugly, it squeaks and creaks
Engine:
The engine is capable of serious power and great response. Be warned the head studs are cheese and will leak/lift with almost any detonation. The OEM injectors run out of flow easily so be wary of an M35 Series 1 with an exhaust but no other supporting fueling mods, it will most likely already have a broken piston. Every M35 series one I have compression tested have had at least one piston broken(greater than 10% compression variance). Rocker cover Gaskets go hard and leak. Electronic throttle isn't the most reliable. The coil packs don't like Adelaide 48 degree heat.
Transmission:
This will start slipping on mid throttle changes on the OEM setup when boost is increased and destroy itself. Can only be patched with a shift kit
Brakes:
The brakes are hugely undersized and will wrap and crack with any spirited driving.
Electric Windows:
The drivers window motor will eventually strip the inner cog. OEM window motors are expensive.
Rear Sub Frame:
They can crack at the top of the inverted U. You can't tow
Electrical:
The Battery Control Modules are almost all been water damaged at some stage due to blocked drain holes. The rams in the front seats are prone to setting off intermittent Air bag faults. Centre pop up screen is useless, even when converted to English
Stereo:
The original Bose system sounds good, changing it requires a bandwidth adaptor(PAC-OEM2). People charge insane amounts for a Double din fascia.
Summary:
Buy the series 2, 2wd version with the 3.5ltr if you don't plan on modding the series 1 turbo. If you are looking at going down the turbo path, don't modify it unless you are (a) very patient and capable of your own work or (b) are willing to spend big money with a workshop who actually knows these cars. Buy the car will all the options that you want already...ie AXIS, leather, sunroofs, radar cruise etc. Don't by a turbo version without completing a compression test.
Matt
Edited by BoostdR
8 hours ago, BoostdR said:
Problems
Turbo Failure:
Rear Shocks:
Rust:
Air Flow Meters:
Interior:
Engine:
Transmission:
Brakes:
Electric Windows:
Rear Sub Frame:
Electrical:
Stereo:
Summary:
Matt
Reading you post Matt and i don't want a stagea anymore :).
In other news;
No other car ever built in the history of motoring has ever had any kind of reliability issue.
So probably just go & buy one of those.
Maybe a Jeep; they seem quite good.
  • Like 2
Stock is fine, especially for what I have found so far in these cars... Compared to an "Aussie" made equivalent it's a stark difference in what is considered stock.. And largely where it's tempting to have fun and go all out, I am personally trying to keep it "stock"....
Where OEM parts are available, I would largely go for them, but at the same time, if it's cheaper to put something potentially better on, I know what I would rather do...
So get a PM35.
No turbo to worry about
Different AFM (seems much more reliable)
Nicer interior
Common engine
Updated transmission
Really, the only downside to the 3.5L is that there is no turbo.
  • Like 1
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
