I agree. I love the black leather & electric seats, but the switch gears digs into my thigh a bit on longer trips.
There is a Nissan service bulletin that covers a (potential) fix for this - I posted them on m35.info forum - but I've still not bothered to try it.
  • 4 years later...
Bit of an old thread, but does anyone still do the English conversion for the stereo ? Have just imported an 04 ARX, replaced the suspension with mca x-r's and bushes are up next before it goes for a blue slip.. But the stereo is the next priority after that.. I'm in Sydney if that is relevant.
Many thanks in advance
Ps has anyone been able to get the maps working for Australia ? Not overly important, but curious all the same
I've never seen that second pocket! Mine has a weird Panasonic DVD drive in there for the GPS system.. that'll get ripped out eventually :P
I got it from yahoo auctions in Japan. Yours may have had the screen from factory as mine had the dvd rom in that area.
Problems
Turbo Failure:
If the oil lines get blocked, yes your turbo will fail. Clean or replace your lines and your good to go. Drilling your banjo's to 3mm will just cause excessive flow  and encourage oil to leak out the turbine oil ring causing smoke.
The main failure is the ceramic turbine breaking off the turbine shaft. Oil flow is not related to this. The cause is directly related to turbine speed. If you want the OEM turbo charger to last, don't put a dump pipe or exhaust on it, Don't increase boost otherwise it will fail eventually.
Rear Shocks:
Upper Mounts will rip out of the car when performance shocks are installed or even with OEM. The top hats rust out due to the stupid design
Rust:
They like to rust in the lower kick panel, window frames, gearbox mount point.
Air Flow Meters:
The OEM Airflow meters blow continuously. Best by a AFM off ScottyM35 as these are the only ones Ive seen last.. better than getting stuck..buy one straight up
Interior:
The interior is just ugly, it squeaks and creaks
Engine:
The engine is capable of serious power and great response. Be warned the head studs are cheese and will leak/lift with almost any detonation. The OEM injectors run out of flow easily so be wary of an M35 Series 1 with an exhaust but no other supporting fueling mods, it will most likely already have a broken piston. Every M35 series one I have compression tested have had at least one piston broken(greater than 10% compression variance). Rocker cover Gaskets go hard and leak. Electronic throttle isn't the most reliable. The coil packs don't like Adelaide 48 degree heat.
Transmission:
This will start slipping on mid throttle changes on the OEM setup when boost is increased and destroy itself. Can only be patched with a shift kit
Brakes:
The brakes are hugely undersized and will wrap and crack with any spirited driving.
Electric Windows:
The drivers window motor will eventually strip the inner cog. OEM window motors are expensive.
Rear Sub Frame:
They can crack at the top of the inverted U. You can't tow
Electrical:
The Battery Control Modules are almost all been water damaged at some stage due to blocked drain holes. The rams in the front seats are prone to setting off intermittent Air bag faults. Centre pop up screen is useless, even when converted to English
Stereo:
The original Bose system sounds good, changing it requires a bandwidth adaptor(PAC-OEM2). People charge insane amounts for a Double din fascia.
Summary:
Buy the series 2, 2wd version with the 3.5ltr if you don't plan on modding the series 1 turbo. If you are looking at going down the turbo path, don't modify it unless you are (a) very patient and capable of your own work or (b) are willing to spend big money with a workshop who actually knows these cars. Buy the car will all the options that you want already...ie AXIS, leather, sunroofs, radar cruise etc. Don't by a turbo version without completing a compression test.
Matt
Edited by BoostdR
8 hours ago, BoostdR said:
Problems
Turbo Failure:
Rear Shocks:
Rust:
Air Flow Meters:
Interior:
Engine:
Transmission:
Brakes:
Electric Windows:
Rear Sub Frame:
Electrical:
Stereo:
Summary:
Matt
Reading you post Matt and i don't want a stagea anymore :).
In other news;
No other car ever built in the history of motoring has ever had any kind of reliability issue.
So probably just go & buy one of those.
Maybe a Jeep; they seem quite good.
  • Like 2
Stock is fine, especially for what I have found so far in these cars... Compared to an "Aussie" made equivalent it's a stark difference in what is considered stock.. And largely where it's tempting to have fun and go all out, I am personally trying to keep it "stock"....
Where OEM parts are available, I would largely go for them, but at the same time, if it's cheaper to put something potentially better on, I know what I would rather do...
So get a PM35.
No turbo to worry about
Different AFM (seems much more reliable)
Nicer interior
Common engine
Updated transmission
Really, the only downside to the 3.5L is that there is no turbo.
  • Like 1
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
