I have had my rb25 neo rebuilt and have discovered the joy of piston slap with forged pistons when cold. When they're cold there's like an 8 thou clearance from piston to bore to allow for mega expansion; it blows smoke and sounds like a diesel until it's warm (which generally happens by about the end of the street); I suggest there's no way the compression will be as high under these conditions, and perhaps it could even be a 25-50% difference like you're seeing here.
sounds like it was built a bit looser then it probably should have been.
nothing worse than piston slap, and it just gets worse... my first car ( cordia turbo) had it bad and even after a rebuild was still slapping away, if your very particular about your car it annoys you everytime you start it, i think all that rocking scuffs the piston and rings, and just accelerates wear and tear.. not to mention sounding like its a worn out engine....
Its very worthwhile to do that important work yourself or inspect it, cause what i thought was a good boring out of my block turned out to be a rough as guts quick job and resulted in piston slap and low compression on a rebuilt motor ( no forged pistons), rings wouldnt bed in and it was a mess...
all those measurements of a thousandth of an inch make big differences, and mechanics can be very rough and approximate instead of precise and exact...
the difference between a motor with perfect clearance and precision compared to others can be huge, sounds rough and dowy compared to sweet and quiet....
8 thou is pretty massive, why so big?
If it is blowing smoke when cold it means the rings haven't properly bedded in, this isn't right. 4 thou sounds better for a street car to me.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
