Hey guys , I have a stock r34 however the previous owner in japan seemed to installed a HID kit in the car. Yesterday my light had blown and so when i went to replace i discovered it was a weird looking bulb.( See below)
Can someone please tell me if the globe i have is a regular xenon globe or is called something else, and where possibly i could get them? Im located in Melbourne
Also if i do find a pair and they are 55w does it matter if put them in, even though the one i took out was a 35W bulb?
Many thanks in advance
Anu
https://www.sau.com.au/forums/topic/369522-xenon-lights/
Ebay Gives answers
HID D2R 35W Bulbs
That is basically all the info you would need to go get the bulbs from a local shop (autobarn might be able to help)
Take one in with you if your worried. Most HID bulbs for cars are 35w I think anyway
EDIT: These look like the exact ones Phillips globes
Edited by 89CAL
https://www.sau.com.au/forums/topic/369522-xenon-lights/#findComment-5890275
55w is going to be a lot hotter and brighter than your 35w, so there's chances that you might melt something in your headlight if you go too hot :P
But generally speaking, from normal driving, you wouldn't need anything more than 35w, it will be bright enough for the roads.
https://www.sau.com.au/forums/topic/369522-xenon-lights/#findComment-5890349
they aren't factory option hid's?
they look like the factory ones. if they are i got a replacement set from a guy on the forums, but i think he sells them through an ebay business now.
worked out a lot cheaper then replacement ones through an auto parts store.
https://www.sau.com.au/forums/topic/369522-xenon-lights/#findComment-5890714
Whoa thanks for the replies guys , so i did more research and i found that no auto stores stock them , i need em asap so yes ebay it will have to be
I looked on ebay and there are some that have D2R and D2S and from what iv read is that D2R have a reflector shielding to reduce glare and the D2R dont, yet they say they will both fit in the car.
If i settle for the D2S i should be alright i rekon.
Any thoughts?
Thanks
Anu
https://www.sau.com.au/forums/topic/369522-xenon-lights/#findComment-5892057
UPDATE!
just bought some globes of a local dude 30 bucks for the pair. Score! they were D2C's the base had cuts in them to fit both D2R and D2S.
I only replaced the right one cus it had blow and to also see what the new ones were like, they are only a tad brighter than the left hand side one probs because the left one is old and is dying out.
Thanks for all the reply's and the great info people !!
Anu
https://www.sau.com.au/forums/topic/369522-xenon-lights/#findComment-5892506
what you had in yr pic is what i found in my glovebox. what i have in my headlights is H1 globes 55w with a adaptor disc. Is what you have the original jap bulb that is supposed to be replaced when the car is complianced for australia?
Also, does the back of your globe when inserted into its holder have a fold down wire clip to clamp down?
https://www.sau.com.au/forums/topic/369522-xenon-lights/#findComment-5893182
