Hey guys,
Thinking about painting the wheels myself. I've never done it before but I looked up some guides and vids on youtube thinking that I could do it.
Heres what I got so far, and correct me if theres any mistakes:
Requirements
1 or 2 Car Jacks
Painters Tape
Lots of Newspapers or those Card thingos
3 or 4 Sand Paper 150-320 grit (any recommendations?, different sources giving different numbers)
2 cans of Primer
2 to 4 cans of Engine/Wheel Paint (any recommendations?, I can only find Duplicolor Metalcast and 3m Engine Enamel Black Gloss or Black Matt, any of these good?)
2 cans of (Resistant?) Clear Coat
Process
1. Remove Wheel properly
2. Clean thoroughly well and Dry
3. Sand wheels and wipe off
4. Tape and cover Tyre
4. Spray with Primer and wait to dry
5. Sand Again ? ? ?
6. Spray with Wheel/Engine Paint and wait to dry
7. Repeat 6 three or four times. (Any recommendations? How many times?)
8. Spray with Clear Coat. (Do I repeat this step too? )
9. Wait 24 Hours before driving.
___________________________
Is it cheaper to get a professional to powder coat it or something?
Before I do anything I got a question, will it look better if the wheels were painted black?
https://www.sau.com.au/forums/topic/369543-black-rim-painting/
first up......I think they will look real nice in black :)
im not very good at painting myself....but for the record....I have painted my dash...my boot....my engine bay....n one thing I can say is sanding is CRUCIAL..n makes ALL the difference !!
For the sandpaper, forget the 150 grit and replace it with 400. 150 is too course, I would only use it to remove a lot of material. When painting, all you are doing is roughing up the surface to give the paint something to grip on to. If the wheels are in relatively poor condition then start with some 240 just to get the imperfections out. You want to spray the 400 to get the best finish, so if the wheels are in good condition then just rough up the surface with the 400 until it loses it's 'shine' and takes on a matte appearance. Make sure you do a really good job of that. Then it's ready to spray.
As for the paint, make sure it is metal paint. Primer is probably unnecessary unless you sand all the way through to metal, you don't need to prime the old paint. Up to you though. But here's the thing: DO NOT LET THE PAINT DRY BETWEEN COATS. The reason for this is there are essentially two forms of paint bonding, physical and chemical. Physical is what you just achieved with the sanding. It is not as good as a chemical bond. If you let the paint dry, you will need to sand it again to make sure it bonds.
What you want to do is let the paint dry to the stage where it becomes sticky to touch but is not completely wet still. So spray the first coat, and then use the overspray on the newspaper to gauge how dry it is. Will probably take about 5 minutes to get to this stage. Then spray the next coat. I would do 5 base coats, and then move onto clear coat. Again, don't wait for the base coat to dry before spraying the clear. Do the same as above. I would do 3-4 coats of clear.
Good luck Eh :)
Dont paint them. I used VHT wheel paint which was meant to be chip resistant. It looked awesome for the first while then they started chipping. Its been a while and they haven't faded at all just the chipping is shit. Almost anything will chip the paint and cause damage to it. I prepped them up pretty well. Gonna sandblast them then have them powder coated.
Go matte buddy.
Also a single can of autobarn wheel paint does 2x wheels.
Clean it up with acetone and spray away. I didn't mask mine either.
Pull the wheels off.
Newspaper on the ground.
Acetone the wheels very very well.
Wipe down again with clean rag.
Make sure can has been shaken very well.
First coat, very light. you should still see some of the original colour.
Do the same for the next wheel.
By the time you have done that, move back to the to other wheel and give it another spray.
Move back the to the second wheel, spray.
Wait 5-10mins.
Spray again, move to second wheel.
Wait 5-10mins.
You will get 4-6 coats out of the can.
The wheels will remain 'glossy' until they dry. Do not use the wheels for 24 hours.
Use a consistent sweeping motion, you should be fine.
Don't do it if it is cold outside.
2x $17.50 spray cans
1x $10 acetone
1x $10 Roll of rag
Thanks guys.
Finished painting the first wheel.. so far so good..
Unfortunately for me, I only have 1 jack.. and the spare tyre is deflated.
So 1 wheel at a time for me.
After the last coat, how long should I wait to put it back on the car to dry, so I can do the next wheel?
Of course I won't drive it. But I want to get it all wheels done asap before I have to drive again.
Or is it not a good idea?
Need advice fast !
1st wheel holding the car now.
I asked my bro if I could borrow his spare tyre and it didn't fit !
So I just got his jack instead.. borrowed my mums jack too so that I could do the next 3! thumbsup.gif
The last 3 wheels are done and now waiting to dry!
Am I doing it right? Looks good to me.
Just waiting for it to dry for the matte black look I guess?
It took me a long time and lots of pain. Maybe not a long time, but constant PAIN!!!-ting. My hands are hurting bad. I'm so unfit !
It's been almost a day and the first wheel doesn't look matte black. I'm getting worried.
Is it normal?
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
