Hi everyone,
This is going to sound very stupid, I did google it but couldn't find much info... My front Tyres are directional Tyres and I've just found out they are in the wrong direction! I'm not going to have a chance to fix it until the weekend BUT what can actually happen of you have the tyres going in the wrong direction?
I noticed a few days ago the car was understeering in the wet when i was changing gears when I was driving in a straight line, hence why I thought I'd check them... Would the tyres going in the wrong direction be the cause of the car understeering?
https://www.sau.com.au/forums/topic/369544-directional-tyres/
Hi everyone,
If your tyres are directional either driving or steering, they will essentially be "sucking up" water instead of dispersing it. Now there is no need to have the tyres removed off the rim to correct the problem... it should be as easy as swapping rims from either side of the car which will reverse the tread pattern direction to then be the correct way!
It's not as 'stupid' a question as you might think... I have seen many cars on the road that have directional tyres on backwards (I always have a bit of a chuckle to myself).
Directional tread patterns are essentially only designed to work properly when they rotate in the right direction... Although they will still disperse water and provide dry grip they won't work anywhere near as well when rolling backwards... Especially on wet roads.
They probably are to blame for your car under-steering in the wet because at driving speeds (anything over about 30kmh) they aren't able to channel water out of the tread grooves efficiently enough and the directional tread sipes aren't opening up to provide extra leading edges to cut through the layer of water and grip the road underneath.
As Global_warmer suggested: just swap the wheels from side to side and you should find that they'll perform much better. :)
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
