1. ARX rims are 18 x 7.5 JJ, +40 offset.
2. I don't have any recommendations for tyres yet but the tyre placard says 225/55 R18 97H, although my ARX has 235/50 R18 101V (these came with it when I bought it). Having said this, when I upgrade my wheels I'll be looking at a larger rolling diameter to hopefully correct the speedo and maybe even improve the fuel economy.
3. In the "M35 - Light Changes" thread M35 - Light Changes recently Duncan (Dunc) posted a photo of the indicator bulb. Basically it is a larger version of the parker (T10). I think they are known as T20 and it should be 21 watts as specified in the handbook. I'm fairly certain the rear bulbs are the same as the front.
Cheers
  • Replies 193
Posted Images
  On 16/02/2012 at 12:24 AM, Sydsyd said:
hi guys,
more question: what's this skinny arm called n if anyone has a spare (front passenger side?)? mine is a bit bend so need a straight one...
That is a "Rack end".
  On 17/02/2012 at 11:42 PM, one more chance said:
Hi chaps..
Question - Does anyone know if the VQ25DET turbo to dump gasket is the same as the RB26s? Will install a new system soon and need to know.
Cheers all..
Generally the stock one will go the distance. It is good quality and still using the stock one after turbo change 4.5 years of driving.
+1. I think mine looked perfect when it came out but put it back with a smear or hi temp silicon on both sides just to be sure.
High temp silicone will go hard and brittle on the turbo housing Leon, I only use it if the flange wont seal now.
As there is no real pressure after the turbo the gasket isnt critical, it should be fine even if its cracked. Our turbo outlet gasket is VQ specific and was only on the VQ25det's and VQ30det's, you will need to go through Nissan for that one.
The pre turbo gasket where it bolts to the manifold is a standard T3 gasket and should be replaced whenever the turbo is removed with a good multi layered stainless gasket. Pressures in the manifold can be quite high.
  On 18/02/2012 at 9:23 AM, iamhe77 said:
Part number for the turbo gasket is 14445-4P200 in case you need it. For reference it was only used on Stagea (VQ25det) and F50 Cima (VQ30det)
This may help.
http://justjap.com/store/product.php?productid=20105&cat=&page=1
I hope not! I'd be royally peed if I have to remove the dump again. But I had a look at the packet & it's temp rated for turbos.
In any case, it was only a smear, more to hold it in place than anything else. It all seems OK till now & been on for a while too - see what happens in the next few years.
  On 16/02/2012 at 9:24 AM, zei20l said:
i have a spare for each end, but im pretty sure you can buy new ones. if you get stuck let me know, id really rather sell both as a pair or with the spare rack i have
how much u sell the pair for?
