guys,
anyone here ever buy from this ebay seller?
http://www.ebay.com.au/itm/NISSAN-350Z-3-5-V6-RDA-FULL-SET-ROTORS-SLOTTED-/160588180772?pt=AU_Car_Parts_Accessories&hash=item2563cd2d24#ht_1106wt_1037
is the price OK for 4 discs or do you think i need to shop around a bit more? any suggestion on where else to look?
  • Replies 193
Posted Images
guys,
If they are that's quite cheap :)
  • 2 months later...
How much should i expect to pay for a new turbo fitted? (something equivalent to stock?)
Im finding thats the problem with the warranty's they require frequent services by certified mechanics.
Does anyone know the details of the standard mandatory dealer warranty in australia is it 3months?
Dealers have a stat warranty on Cars under 10 years old of 3 months / 5000kms. That will cover everything on the car that goes wrong in that period as I understand it.
Dealers can offer extra warranty that is offered by a 3rd party warranty company. This can be for various amount of time/kms. Generally this cover will state it will cover damage to the drivetrain upto a total of $XXXX.
So an example. You buy a car and you have bought or the dealer gave you a 1 year 3rd party warranty. 6 months in, you having had the car serviced as required by the dealer, blow up the turbo. The 3rd party warranty will cover the claim up to $2000 (just say). The job will cost $3000, so you will pay the gap.
Thats how I understand it works.
some of the guys that have replaced turbos will be able to give you a cost.
I would quote you under two grand for the highflow turbo fitted, well down on the 3 or 4k it used to cost. (and what a mechanic would probably still charge.)
There is no guarantee you will get what you want with the warranty, most probably they would try and source a second hand turbo, and you would be in the same boat again down the track.
What Pn-mad said. Dealer/ broker whoever sold you the car ( not private sale) has to give you the 3months 5k stat warranty if under 10 years old and fix the issue repair. Otherwise they can take back the car and refund you in full. If not you can get Aca involved running a program that will call the dealer direct within 5 days and sort. If no comply then go to vcat. Claim under 9,999.00 and they can't get legal representation. His word against yours.
PS Scotty your offer sounds bloody good!
Tell me about it, between the cost Stao is supplying rebuilt turbo's at, and the speed I can change a turbo in now, you would be mad to purchase their dodgy warranty. Mine wasn't worth the paper it was written on...
Ive still got the invoice the previous owner of my car paid for the highflow and refit of the turbo on my car; to the tune of $4800 or there abouts
Faaark. Mine cost just under $2k installed back when it was done... I didn't get a say regarding the internals (not that I would have known anything about it back then
I think they took the engine out the hard way and just generally didnt know how to best approach it, likely wasted heaaaaaps of time. Just glad it wasnt me that had to foot that bill!
    • Jap premium will be 100 RON. You should use 98.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
