Faaark. Mine cost just under $2k installed back when it was done... I didn't get a say regarding the internals (not that I would have known anything about it back then
They heavily under quoted your job mate, they wouldn't offer the same deal now though I bet.
  • Replies 193
Posted Images
A word of advice.....you spend less on an m35 you'll end up spending more!
Don't ever believe the kms you see on these cars! Get em on a hoist and inspect it....check out the bolts on the heat shields.....and check out the a/c filter.
Some cars do have legit km's on them, mine does as I imported it myself. Just ask the dealer to see the original Japanese government de-registration certificate, NOT a copy of it, THE original certificate. This will tell you if the km's are true or not.
Paul - agree with what you are saying about some cars having legit odo readings.......most of the cars are actually 'wound back' or had their instrument clusted changed before going through the auction houses in Japan and before they are 'de-registered' in an attempt to fetch more $$$$. It is extremely easy to get a lower odo on these cars, and as most know, some import yards consistently have cars with 40,000 - 70,000km as Mr 20Valve had (not just M35's either - but all cars in their yards).
So, the de-registration certificate will not necessarily tell you if the km's are true or not......
Agree with Craig - thorough self inspection if buying locally, or a well regarded and trusted broker/contact in Japan if buying from o/s with lots of pics requested......
Edited by prince_skyline
It is a good way to check as the dereg paper has the last 2 odo recordings on it in 2 yr intervals. So for example if it had an inspection in 2007 with 50,000kms and another inspection in 2009 with 65,000kms on it and you buy it in 2011 it would have around 80,000 km's on it going by the amount done over the last 4yrs. If you bought it and it had a lot less km's on it than around that, such as if it had 40,000kms, then yes it's a typical wind back job. Not all are like this though, that's the point of asking to see the dereg paper.
When I have time I'll scan one of my dereg certs so you can all see what I'm on about.
And it usually gets wound back after the auction not before. I've seen a lot of cars marked on the auction sheet as having "unsure" km's. I've even actually been to one of the big auction houses in Nagoya and seen it first hand myself, not them being wound back but the auction sheet stating unsure km's. The auction houses are very good with the records of car details.
Edited by slippylotion
I am very weary of the cheap ones with low klms i have looked at a couple latley. Will deffinatley ask for dereg certs next time, My mate bought a 2002 RS with 50,000 kms immaculate inside and out for $13, 888 this is kind of what i am gauging my prices off as i am after a similar model, kms etc. What would you guys pay? the redbook gives a very broad price range, a bit like the sales market at the moment.
  • 1 month later...
anyone using other sizes?
i used the tyre size calculator, the rolling diameter of 245/40/18 is less by quite a bit compared to stock...
planning to get new tyres in the next couple of days, any help is appreciated
thanks guys!
thanks guys!
245/45/18" reduces the speedo error from almost 10% to around 3% on an RS/RX. AR-X is is different again. But they will be more expensive than 245/40/18's
A bit more sidewall gives a slightly better ride, and fill the arches well if your ride height is right.
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
