350-400kms on 3/4 of a tank isn't that bad. 3/4 of a tank is ~60L, that's 15-17L/100Km, which is what I get when I behave :ninja:
I can get mine down to 12-14L/100 on a trip, but general city/highway average is 15-17L/100.
  • Replies 193
Posted Images
That neglects to take into account that when your guage hits the lower line it isnt empty :P
But yeah, if the CEL is on - and you've read the codes off and it says O2 sensor.. a) check its plugged in, b) replace it :P
Not accurate there Ryan.
Set your trip when you fill up, then next fill take note of how many litres the tank takes to fill.
kms travelled / litres to fill = km per L
Then divide 100 by that figure to work out your L/100kms usage :)
EDIT - yes, I know... :geek:
Edited by iamhe77
alright, got myself a set of BC racing type BR coilovers...gonna do installation myself with a help from a mate this weekend (if i get lucky when no one calls from work)...i can work out how to take off the fronts, but how to take off the rears? i mean how to access to the top part of the rear suspension which is covered by the interior...
tried searching on SAU for any DIY on this, couldn't find any (maybe i didn't search hard enough?)...any links or pics would be a great help...thanks guys!
Easy!
Remove wheel, follow shock to mounting point on chassis rail, undo 2x M10 bolts (13mm hex, I think). Easy!
Unless the design of the BC top rear shock mount has changed; you will ned to re-use the pressed steel OEM top mount (The cup shaped bit that bolts to the chassis). The BC rubber bushes and crush tube fit perfectly into the OEM mount, so WD40 the shock thread, and remove the M12 nut (17mm socket) you might need to lightly clamp the shock in a vice to stop it turning.
Only takes a couple of minutes each to change, and you're on your way. I recommend running the shock at it's shortest extension rather than OEM length. Wind it all the way into the bottom clevis until it binds, then a full turn out If you lock it up with the bottom clevis bottomed out, over time it may lock in the thread and be impossible to disassemble later on. Lock the tapered collar and you're good. Also the bottom clevis is slightly too wide IMO, I used a 1.5mm thick M12 (or 1/2") washer to take up the gap as the clevis will have to crush miles too far otherwise. You could easily machine some small spacers if you have access to a lathe, but washers worked fine.
To remove the STD rear spring it is easier to undo the inner mount for the lower arm (one with the spring seat) and lower the whole arm supported with a jack. Mark the eccentric bolt on the lower arm before removal. You'll be aligning once you're done; but at least you're no worse off. The STD spring is very long and you won't be able to swing the arm far enough down to remove the spring from the seat.
If you like; I can PM you some base height measurements and some pics of my ride height as a starting point for adjustment. I'm at work at the moment, but I'll do it tomorrow morning.
Edited by Daleo
thanks for that dale, really appreciate it...
gonna jack up the car on the weekend to have a look what's below...fingers crossed it's not raining in melbourne on saturday, can't work in a garage with 2 bloody wagons and lots of stuff around lol
Easy!
+1 please :)
hey guys,
i need help as i'm still clueless on what's going on...
the car has ECL on a few weeks ago, checked the codes manually, came as 1111, 1110 and 1135...i checked against the list of ECU error codes, nothing of that kind, searched online and came up as ECL code for Navara which points into the intake side (all 3 of them)...i asked the workshop that i normally go to and when they checked out the code using OBD scanner, same codes came out and i was told that the O2 sensor is busted...
now i just got the O2 sensor replaced yesterday and today the codes came up again, same ones as above...
anyone has an idea on what i need to look at? need help asap as i'm scared of driving with ECL on all times...
111 = Intake air temp circuit range/performance problem - Try cleaning the AFM
110 = IAT Circuit Malfunction - Lost on this.....maybe a bad air filter
135 = O2 Sensor heater circuit malfunction - Try unplugging this......see if there is any difference on how the car runs
Other than that without seeing the car i cannot help you.
hey guys,
noob question, how to take the gear handle apart? cos i've been driving manual so can't really figure out how to take auto gear handle...need to replace the light for passenger seat heater switch...
hey guys,
Push down the silver ring around the bottom of the knob with a flat blade screwdriver; flick out the spring clip around the bottom of the knob, lift off.:thumbsup:
hey guys,
This is for the whole dash assembley for a G35 Infiniti (V35 Skyline) but the first few steps shows you how with diagrams.
http://documents.victorytechnologies.com//documents/product/9438.pdf
or this one:
http://www.sound-repair.com/index.php/infiniti-g35-03-05-stereo-removal-instructions/
Edited by prince_skyline
anyone with M35 has bought any reinforcement braces (not sway bars)? if yes, do they actually improve handling or at the least work as it's supposed to?
something like this: http://www.oxmotorsports.co.jp/7.html?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
