Faaark. Mine cost just under $2k installed back when it was done... I didn't get a say regarding the internals (not that I would have known anything about it back then
They heavily under quoted your job mate, they wouldn't offer the same deal now though I bet.
  • Replies 193
Posted Images
A word of advice.....you spend less on an m35 you'll end up spending more!
Don't ever believe the kms you see on these cars! Get em on a hoist and inspect it....check out the bolts on the heat shields.....and check out the a/c filter.
Some cars do have legit km's on them, mine does as I imported it myself. Just ask the dealer to see the original Japanese government de-registration certificate, NOT a copy of it, THE original certificate. This will tell you if the km's are true or not.
Paul - agree with what you are saying about some cars having legit odo readings.......most of the cars are actually 'wound back' or had their instrument clusted changed before going through the auction houses in Japan and before they are 'de-registered' in an attempt to fetch more $$$$. It is extremely easy to get a lower odo on these cars, and as most know, some import yards consistently have cars with 40,000 - 70,000km as Mr 20Valve had (not just M35's either - but all cars in their yards).
So, the de-registration certificate will not necessarily tell you if the km's are true or not......
Agree with Craig - thorough self inspection if buying locally, or a well regarded and trusted broker/contact in Japan if buying from o/s with lots of pics requested......
Edited by prince_skyline
It is a good way to check as the dereg paper has the last 2 odo recordings on it in 2 yr intervals. So for example if it had an inspection in 2007 with 50,000kms and another inspection in 2009 with 65,000kms on it and you buy it in 2011 it would have around 80,000 km's on it going by the amount done over the last 4yrs. If you bought it and it had a lot less km's on it than around that, such as if it had 40,000kms, then yes it's a typical wind back job. Not all are like this though, that's the point of asking to see the dereg paper.
When I have time I'll scan one of my dereg certs so you can all see what I'm on about.
And it usually gets wound back after the auction not before. I've seen a lot of cars marked on the auction sheet as having "unsure" km's. I've even actually been to one of the big auction houses in Nagoya and seen it first hand myself, not them being wound back but the auction sheet stating unsure km's. The auction houses are very good with the records of car details.
Edited by slippylotion
I am very weary of the cheap ones with low klms i have looked at a couple latley. Will deffinatley ask for dereg certs next time, My mate bought a 2002 RS with 50,000 kms immaculate inside and out for $13, 888 this is kind of what i am gauging my prices off as i am after a similar model, kms etc. What would you guys pay? the redbook gives a very broad price range, a bit like the sales market at the moment.
  • 1 month later...
anyone using other sizes?
i used the tyre size calculator, the rolling diameter of 245/40/18 is less by quite a bit compared to stock...
planning to get new tyres in the next couple of days, any help is appreciated
thanks guys!
thanks guys!
245/45/18" reduces the speedo error from almost 10% to around 3% on an RS/RX. AR-X is is different again. But they will be more expensive than 245/40/18's
A bit more sidewall gives a slightly better ride, and fill the arches well if your ride height is right.
    • Not that I know from experience, but in theory you'd want your gate spring to be as close to target pressure as possible, so you'd go with the higher gate spring?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
