Toshi Will Coming Back To Qld In 30 Th November (This Month)For Real Time Tune On Road R33 From $550
Beej Im pretty sure the daughter board is remapable as well pretty sure it's exactly the same not 100% or they use an emulator and nistune software.
And toshi sounds awesome budd am very interested car should be done in a few weeks minus my big turbo setup but gonna keep it like that for a little while so will let you kno when car is back from shop and everything done should be in 3 weeks or so.
Thanks mate
I'f I go with the nistune board does that make the ecu remapable ?
Or is the daughter board remapable also?
How much for the nistune and the tune?
Aghhhh mad cybz I can't get over how cheap this will work out :-) so yeah I'll start saving man and when ur ready let me know a d we can organise a third person and we will get tishi to do the remap :-)
R32 do not need daughter board.
I can real time tune and re tune with emulator but I think another shop can not re tune in QLD.
Because they do not have emulator and chip programmer.
Nistune and remap is exactly same performance.
If you want to re tune in QLD you need nistne board.
But I can come QLD anytime.
If you want to tune with nistune please send PM.
Toshi*
Damn I phone
beej we should both just do nistunes that way when we upgrade more and wanna get tuned by like EFI or something then we all good.
and yer let me know brother i got the cash waiting to go just gotta wait for car and the boys at spot on to get the VL started should be going
this week i know my roll cage defs gets there tues, wednesday so as soon as thats in car can go in 4 the rest :)
I'm a lil confused ATM :-(
Toshi do u do the nistune boards? And if so how much with a tune for it ? And I'f I go with the nistune board that will be remapable ? Correct ?
I would be keen to do the nistune I want it to be remapable
I sent PM
Yes,I can get nistune board and ecu tune.
Nistune board is remapable in QLD .
Cost $260.(just board)
But if you want to re-tune in future you are able to install nistune board to ecu later on.
http://nistune.com/docs/NIStune_Type_2_Hardware_Installation.pdf
On mate put me down for the nistune board and I'f u want to fit it too that would be sweet I'f not I'll get it fitted and tuned when it's back on the road :-) pm me with details thanks for your patience answering questions
  • 1 month later...
I will go back QLD NOVEMBER (this month).
If someone interesting please send e-mail , PM, SMS or call me.
Ph 0410490049
e-mail [email protected]
How to tune on road
I will fit wideband air fuel ratio meter(same dyno machine O2 sensor), and lap top computer, Gizzmo KMon Knock Monitor & Analysisor,before we leave.
While the customer is driving,I will sit in the passenger with my laptop.
Start with 2nd gear, winding up from 2000rpm-5000rpm to check car condition and datalog.
I will make fuel and timing map then 2nd gear again to check air fuel ratio and engine knock.
After making rough map on 2nd gear, we will go to freeway .With 3rd/4th gear, we will be running on freeway from 2000rpm-3000rpm to check engine response and engine knock.
Then next 3000rpm-4000rpm ,this will be repeated in increments of 1000rpm.If we find flat spot , slow response , laggy,engine knock etc I will fix and tune on freeway.
After that is done, we will go to small mountain then check response and power feel.
Take around 4-6hours.
If customer would like to check power and power curve etc we will go to nearest dyno shop.If necessary I will adjust fuel and timing map ondyno. We will return via route with small mountains to further check response and power feel.(this is road and dyno tune)
1)R33 Road tune remap Price from $550 (not with NISTUNE board)
2) ROAD TUNE and DYNO TUNE labor Price from $600 plus dyno hire $80-90
This thread tune for Z32 on road tune.
I remapped ecu planetrobbis car in QLD (This is not NISTUNE)
http://www.aus300zx.com/forum/showth...ighlight=toshi
I tuned NISTUNE sbes NA car in VIC.
This is my thread on skylines Australia.
I tuned over 150 RB engine cars.
http://www.skylinesaustralia.com/forums/topic/210097-nistune-powerfc-fcon-remap-ecu-road-tune-and-dyno-tune-available-in-sydneysending-to-other-state-and-over-seas-also-abailable-now/page__hl__toshi
Ph 0410490049
    • Apologies if I sounded like a arse My point was that you will not be able to buy a rotisserie that suits your car, you get the rotisserie frame, and then fabricate parts to mount the rotisserie frame to the body The rotisserie side is easy, but the fabrication of the actual mounts is the tricky part, where to mount so you don't bend/twist the body, plus the geometry involved to get it to turn  If your capable at fabrication, and can work out where the C/L is in relation to the weight is so it actually can turn, you should be sweet I would love to see the progress on this just for the thought processes and fabrication
    • Type "M2" means it's a series 2. I would not be shocked to learn that the production changeover was somewhat lax and a late 12/95 production car actually got mostly series 2 parts with a bit of series 1 leftover. Post the VIN and it'll be easier to investigate.
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
    • I've ordered a new fuel pump and plan to do all the fuel tank hoses at the same time. Those are the hoses I would rather not go on the road.
