^ you missed a few spots with the colour history brush tool. People still do that sort of stuff?
What made you do that to this picture? Just curious.
To me its cheesy and makes the image look worse. My 2 cents. Sorry dont mean to sound harsh.
Otherwise even lighting on the car.
  • Replies 161
Posted Images
Hey guys, I'm building some stuff for my video rig and though I'd share this one since it will also work for any SLR zoom lens.
I wanted a more controllable way to zoom when I have my camera in video mode.
I got this downspout clamp from Bunnings for $5. I just cut the tabs and drilled a hole to put the clamping screw through (a nice long one from one of my extra follow focus gears).
It really turned out well and the zoom is so much more fluid and smooth since I can control it better.
Just thought I'd share.
hey nice! i was thinking about something like this for doing 'zoom burst' photos.
where did you get that threaded bolt type thing (do they have a specific name, lol)
finding stuff like that is half the battle when it comes to making cool stuff like this
I love your ghetto mods pezman. they're rad. we should make a new site called ghetto-mods.com! :P
I had a crack at some studio styled shots the other day, just did a few quick adjustments here... what do u think? I've spotted a couple flaws on most them already but feedback is gold.
Haha yeah. Such a good colour. Blue just pops so much easier.
BTW - Those Fiat 500 shots, did you paint the shadows in? First shadow looks a lot "real-er" than the rear shot. Or maybe it's the low angle and shape of the car, looks like a pyramid haha.
Such a rad car. I want one!!
The screw was from another accessory I have for my camera - some big follow focus gears. But I figure if you used some threaded rod you can just lock a couple of washers on one end between two nuts to make a thumb screw and then you just need some round or triangle pieces to drill and tap. Really Easy.
Had an hour or so to play with my new lens and wanted to see what it can do for night photography (Panasonic 20mm 1.7 Prime). These are really just a trial run to make sure I can get decent capture of stars. I want to do some star gazing time lapse with an intervalometer. I'm pretty pleased with the results straight out of the camera.
Kory, love the S15 shot! I agree, that blue looks amazing on them. When I was deciding on a car almost 6 yrs ago, it was either going to be a blue S15 or the LOLvo.
Matt, that little 500 looks odd from that angle.
Thanks Nick :)
Rainbow beach looks epic!!!
alan_key - Do you live on the beaches? And have you been looking at The-Lowdown lately ;) Turned out good! Maybe use another flash on camera right for some more fill and to kill the shadows?
Another from Bree's Shoot.
That rainbow beach shot is awesome. really, really well done.
Did you cut and paste the stagea over a 370z? hehehe, nice shot there man. clean looking stag too!
Turned out quite nicely Kory... Story... Allegory... Montesory.... Bory.... Floory.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
