  • Replies 161
Posted Images
Nice! About time I had a fellow Stagea driver in this section. Welcome to the forums, and welcome to Stagea ownership. :D
alan_key - Do you live on the beaches? And have you been looking at The-Lowdown lately ;) Turned out good! Maybe use another flash on camera right for some more fill and to kill the shadows?
Yeh i live on the beaches. and haven't heard of that site till now, seems like they've been using that spot too ha. Nice rig shots, wish i had a decent rig
Edited by alan_key
During my lunch break yesterday, I snuck down to the creek to find out what was making all the noise.
Oh yeah... found out that some of my V8 shots from clipsal will be used in the Bisley Workwear catalogue coming out soon too :)
I live on the Beaches too Alan. If you see a white evo 8 MR driving around give me a toot! :)
Will do!
MaTBoy nice shots, just wondering do you use a monopod or tripod when you're panning? last time I just did it handheld with IS and was getting pretty inconsistent results, either i just need practice or im doing it wrong ha
I never use a monopod unless i'm holding a 400 2.8 or 500.
Turn the IS off and practice your technique more. Panning is all about technique. Unless you were shooting stupid shutter speeds below 1/15th. I'd recommend starting at 1/100th, get consistent results, then drop down to 1/80th etc...
I usually pan at around 1/40th-1/60th depending on if i'm getting paid or not lol.
Hey Fellas, had a good play with the camera last night. Some serious effort and some just goofing around.
Hey Matt, Kory & Nick these are taken at the netball courts just behind my house. It backs onto the bush which makes it a great locale for the dark bush sihouettes. We should set up a meet there and see what you fellas think of the location.
(I call that second to last photo - "my rocket ship")
oh yeah, was going to add that I bought a ball cap from bunnings that has 3 l.e.d.'s in the brim. one directly straight ahead and two pointed down from the brim at about 30 degrees. It worked a treat for this kind of work. Was funny cause I kept feeling like the Blair Witch project with the light pointing any direction I looked.
Was well worth the $20. For you noctural photography buffs would highly recommend.
patience, my young padawan apprentice. In time the power of the dark side will reveal itself to you.
Location looks quite good. worth a future investigation. Good to see you're out there playing around :)
here's a couple from twilight on friday night.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
