Car Walk Around
On The Track
Plenty of other pics in my Album on photobucket.
I am parting out my 1998 Series 3 R33 GTR Vspec. Absolutlely everything is available. The car is registered and undamaged. The motor was built up over a 10 year period with the help of James from Nisspeed Morpowa, Advan Racing and PM engines. The motor is very similar to John Munro's $100,000 build. Mine has additional developement on top. We took what worked and made it better. Every part is there for a reason and has been matched, tested and developed through years of experience. The aim was to build a very responsive motor with a broad torque curve and makes 500awkw. The motor has only travelled 3,000km since completion.
I will list what i can think of and add more parts when I can. If you don't see it listed, then ask as I will probably have it.
happy to post (located in Adelaide)
happy to discount for multiple item
Reinmax Oil Pump(massive flow) $700
The spring pressure has been modified to Nisspeed specs, works perfectly with a 1.1mm block restrictor.
This is a High Flow Oil Pump designed by RB26 tuning specialist, Reimax.
The Reimax Oil Pump is the perfect replacement for the Achilles Heel of the RB26DETT. The OEM unit is notorious for starving tuned RB engines of oil at high RPM`s.
The Inner Rotor size has been increased from 77mm to 85mm, and the thickness of the rotor teeth has gone up from 11mm to 12mm.
The metal composition of the pump has also been changed from Sintered Alloy to SCM430H.
At 6000rpm, the Reimax High Flow Oil Pump flows 70L/min VS 47L/min from the OEM unit.
The pump's Regulator Valve opens at 7.2kg/cm2 (+/-0.3kg/cm2) of pressure, at 2000rpms, or when oil temperature hits 80 degrees Celsius.
Not only does this item boast great figures, it has also proven its build quality in Gr-A races throughout Japan.
RB32(just under 3.2)$3500 Block with:
Custom ordered CP pistons(used, matched to bore)
Sonic tested and Cryo sleeved
Billet twin cam belt pulley adaptor
Stainless steel Welsh plugs
1.1mm head restrictor
Nisspeed 4WD sump Adaptor
Block milled for high HP Sump adaptor fittment
ARP head stud kit
Nisspeed oil pickup for extended Sump
RB26 Sump, extended with Baffles and Gates
Bore has been cross hatched for reinstall of pistons
Decked
RB26 Head $3000 with:
JUN IN EX 264 9.5mm CAMs
Tomei Type B valve springs
New Valve stem seals
1mm Over Valves
Ported by PM engines for max response and hp (the right way..not enlarging the ports)
Deshrouded valves
faced
ARP cam stud kit
OS Giken Adj Cam gears
6boost Twin turbo manifolds $1000
Heat wrapped and thermatec coated
Intake hard Pipe kit $200
Modified to fit 6boost setup
Modified Power steering resevoir relocator for use with hard pipe kit $180
Custome bracket
direct bolt on with charcol canister
Apexi turbo inlet hard pipes $400
for Z32 AFM
Z32 AFM x2 $200
HKS GTRS x 2 turbos $2,000 with:
HKS adj wastegates
ported & match turbine housing
Tomei Dump pipes, $500 with:
Heat wrapped
Oxy sensors
ROH 19" x 10" 3 peice Modena's $2500
Nangkang 275's
4" of dish all round
Shadow crome finish
ROH 18" x 10" 3 peice Modena's $3000
Michelin 270 full slicks
3" of dish
Three layer pearl
Used for one day only
Michelin 270 full slicks x 16 $150 each
various levels of use
Custom exhaust $1000
75mm x 2 into 90mm into 127mm internal muffler
comes with 75mm x 2 Side pipes for track
New Vbands 75mm x 6 also thrown in(not fitted) but for quick change
ARC intercooler 100mm+ thick $1500
Good condition
one in one out
Greddy Copy Plenum $500
with silicon 80mm-100mm adaptor
Nismo Plarque
Nismo Gmax Twin Plate clucth $1000
Nismo Flywheel
Pull type
50% life left
Can be repucked when the time comes by NPC for $400(both plates)
Nismo Gmax Twin Plate $900
Nismo Flywheel
Push Type
50% life
R33 GTR Series 3 Vspec gearboxes(2) $1000 each
one with redline oil (70,000km)
one with nissan oil (60,000km)
with tranfer cases
R32 GTR Gearbox $800
may have short ratio's, will have to check
Normal oil
45,000km
with tranfer case
R33 last of the series 3 factory leather interior $1200
Front and rear with door cards cards
Drivers seat has some small marks(no tears or actual scuffs)
rest vgc
R33 Xenon Headlights $1200
Greddy High end oil Cooler kit $400
Sandwitch plate has thermostat and anti drain back
-10 stailess braided lines
Black Crinkle coat rocker covers and plenum $450
R34 center emblem
inluded- valley cover, rocker covers, timing belt cover and plenum
Techtom japanese launch control $500
English instructions and wiring diagram
Clutch switch
Field Boxer II linear Torque split controller $800
Specs
tested best for track
Greddy Profec B boost controller $400
The Good one (3 knobs, no display)
Very very stable boost
Apexi Power FC $1100
Commander
Boost controller
FC Data Logit $350
laptop software
Innovate Motorsports LM2 OBD2 Wideband $500
Stainless tail pipe sniffer
Innovate LC1 wide band $80
with sensor
Analogue outouts ok
Couldn't get USB to work
Nismo Style catch can with return to sump $150
Black
JVC DVD player $100
single DIN
No screen-video out
OEL screen
Nismo Center Gauges and Speedo Cluster $750
white
Vspec
Low Km's
Ohlins DFV Suspension $2000
retail $4,000
Dual flow vlave (swedish valves)
R33 & R34 GTR
Very very good condition
serviced by Ohlins specialist last month(
F 10kg R 8kg
Dual Spring
C spanner
All incar adjustment
The Ohlins DFV suspension system is the latest design from Ohlins which incorporates a a PCV valve on the compression and extension sides of the shock. This builds on the award winning PCV suspension model for even greater performance.
Super forged duralumin construction with final teflon
Super lightweight with high stiffness
Designed to balance ride comfort and vastly improved suspension performance
Ohlins Mines Esta Street Edition Suspension $1500
A comfortable ride was achieved at a high dimension with sport quality and balance while regular street driving by adopting the OHLINS shock absorber and the original springs.
In addition to the original specification, the shock absorber has a C ring height-adjustment function and the 20 steps of damping force-control. You can apply your favorite settings.
It gives you the decent driving experience which does not have the sense of incongruity as other types of cars by using the normal spring form and adopting variable rate spring for some types of cars.
This product has been developed and assembled by Mine's.
Greddy Boost Gauge, Fuel Pressure $400
White face
Electronic with recall and alarm setting
includes Greddy A pillar pod for 33
Brembos and discs $2100
Fresh DBA 4000 slotted front disc's
Front and rear calipers
DBA slotted rear discs
Intima front pads 0-700degrees (fitted)
Intima rear pads (brand new in box)
R34 Style gear knob $100
as new
genuine nissan
1-5 gears
Fuel system setup $400
twin 044
some speed flow fittings
BTR surge tank
relays
Carbon Fibre Full length cooling panel $250
R33
Trust front lower lip $350
Much Much more avail, all panels, electrics, driveline etc. Series 3 Vspec.
Matt
0413023669
bro interested in your rb32 block.. can we discuss further trough e mails? [email protected]
  • Replies 164
Do you have a price for the the shell? either rolling or not
Not sure what to ask and what will be left. Happy to have offers.
It is registered and not defected, zero rust, April 1998 model
Matt
ARC intercooler SOLD pending payment.
sorry to thoose who missed out on this (first in best dressed)
Edited by BoostdR
Got my head lights today
big thanks to Matt, very good communication and items were very well packed to avoid damage.
good luck with the rest of the parts for sale,
pleasure doing business with you
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
