Still avialable
Ohlins Mines Esta Street Edition Suspension $1500 ono
-Come with Bilstein 12kg front spring aswell as the original Esta
A comfortable ride was achieved at a high dimension with sport quality and balance while regular street driving by adopting the OHLINS shock absorber and the original springs.
In addition to the original specification, the shock absorber has a C ring height-adjustment function and the 20 steps of damping force-control. You can apply your favorite settings.
It gives you the decent driving experience which does not have the sense of incongruity as other types of cars by using the normal spring form and adopting variable rate spring for some types of cars.
This product has been developed and assembled by Mine's.
  • Replies 164
Still avialable
You don't mention condition or k's travelled. Any leaks or similar? What are the standard spring rates that come with the shocks and are the shocks valved for them or for the 12kg springs? Thanks.
Any pics?
Any pics?
They are in good condition, no leaks, no knocking. Street spring rate. You can check the mines-wave site for info. 12kg springs not avail anymore.
will post a new forsale thread in a sec with pics.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
