My poor ceffy has copped a smack in the rear end so i am parting it out. Let me know what you need and i will do my best to make sure you get a good deal.
Some cool things include autech front bar and sideskirts, genuine cefiro key, locks and ignition barrel, all pannels, glass, doors, seats etc. Just let me know what you need and i'll tell you if i have it. And even better if you want the whole thing. I also have lots of spares laying around. let me know if you would like to me to send you photos.
*will update this post soon*
Chris - 0414389834
Edited by filo_a31
https://www.sau.com.au/forums/topic/369693-wrecking-blue-a31-cefiro-sydney/
price on whole dash loom all the way to headlights with fuse boxes ect posted to melb?
To be honest you don't want want my dash loom, it looks like it has be rewired a few times, and yea, not the best haha
have you got a quote on repair? looks it needs a pull and rear bits
Picked up a rolling shell for cheap.
Damage seems to be, bent lower control arm, punctured fuel tank, bent reo, smashed taillights, smashed rear bar, quarters are rippled and there's a buckle in the roof at the top of the C pillar.
what's the condition of the passenger side door? paint wise?
cheers
cheers
Passenger side door is in good nick, i'll double check it when i get home and get back to you.
empty front cut?? with headlights indicators and guards??
I need the headlights and indicators for my other shell. I can do you a brare front cut with just the guards. The passenger guard is slightly dinged but nothing serious, i can take photos if you like?
pics if you must , postage?? , i only need the guards and rad support and rh side to the firewall (and bar rio) . your ceff looks familiar :ph34r:
I'll take pics for you tomorrow and pm you with the price. I also have a bonnet it your interested. I stupidly threw out the front rio thinking no one would want it haha, but it was all chopped up for the front mount. No sure about postage but if you can organise freight to come to my house in engadine, nsw. That might make it easier.
Drivers window reg sold, passenger rear door lock mechanism sold, passenger seat sold, body kit sold.
STILL HAVE HEAPS OF STUFF THAT NEEDS TO GO WITHIN THE NEXT 2 WEEKS OR IT GOES TO THE SCRAP YARD!!!!
HAVE ALL BODY PANELS, DOOR TRIMS, STEERING RACK, DASH, HICAS LOCK BAR, STANDARD SUSPENSION ARMS AND HEAPS MORE!!!
YOU WILL NOT FIND CHEAPER PRICES AND IF YOU DO I WILL DO BETTER!!!
also have a stright through pipe from the cat to the rear muffler, frosted passenger headlight, rb20det motor and loom with no injectors or turbo (unless i can find my standard injectors that i can't seem to find). May also sell my 21 safety 6 point roll cage (non sunroof) if i cant get it to fit in my new shell that has a sunroof.
  • 3 weeks later...
Shell has been scrapped. Still have doors, with trims and glass, bonnet, rb20 with wiring harness, interior trims etc.
I also have a spare passenger side headlight, steering rack and hicas lock bar
Edited by filo_a31
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
