Mr30 Wiring Question
I have searched and searched for a wiring diagram and have had no luck.
I don't particularly want to go joining wires until i find the right ones just in-case i cause a short and blow something.
On the auto there is 4 plugs, one with a 4-pin connector which goes into the side of the shifter on the drivers side of the box,
and on the passenger side of the box are 2 x 2-pin connectors and 1 single pin connector.
Which plugs and corresponding wire colours wires do what?
The auto box has overdrive so I'm guessing some of the wires are for this.
I need to bypass the inhibitor switch to get the car to start again as i have almost completed my manual conversion and also need to hook up the reverse lights.
Please HELP :/
I did ask this question in my other thread but am yet to get a response and i've been stuck for almost 2 weeks.:(
Thanks Dennis,
I'm at work at the moment, i will give you a call when i can get back under the car either tomorrow or Monday if that is OK with you.
Will be great to hear the beast running again now that I've just preformed a service on it and added a pod filter, some extractors, 2 and a 1/4 inch exhaust system and a 6 inch cannon.
Regards
Shane.
Ok call me on 0406142529 and we can try sorting you out.
Cheers, Dennis
I have to go out, but when I return I'll post some pics of service pages so you can try to work it out.
Wiring colour codes are:
B = Black
W = White
R = Red
G = Green
L = Blue
Y = Yellow
LG = Light Green
BR = Brown
OR = Orange
P = Pink
PU = Purple
GY = Gray
SB = Sky Blue
In case of colour coding using a stripe, Base colour is first followed by stripe colour
eg. L/W = Blue with White stripe
Cheers, D
sweet thanks dude!!!
B = Black
W = White
R = Red
G = Green
L = Blue
Y = Yellow
LG = Light Green
BR = Brown
OR = Orange
P = Pink
PU = Purple
GY = Gray
SB = Sky Blue
Cheers, D
Hi Shane,
Attached is 6 pics.
Pict 0011 is the Ignition System
Pict 0010 is the Charging System
Pict 0009 is the Starting System
Pict 0008 is the Power Supply Routing
The second Pict 0009 is the Overdive Control System
The second Pict 0008 is the Kickdown Switch System
All these are for the Australian car.
From what I read in the manual, the 4 pin plug is from the Overdrive control switch, the 2 pin plugs are Kickdown solenoid & Overdrive cancel solenoid. The single appears to be the Overdrive indicator switch as well, possibly indicator light.
The Inhibitor switch also has 4 wires but I don't know where they go as I don't have any automatic vehicles to look at for you.
If these picture diagrams don't help, your more than welcome to come down and look at the manuals, as I'm just at Campbelltown.
Cheers, D
Thanks mate, those circuit diagrams were exactly what i needed.
All sorted now, it turns out that the 4 pin connector is all i needed to use,
just join the black/white wire to the green/yellow wire to bypass the inhibitor
and the yellow wire and the red wire to the manual gearbox reverse switch wires.
Regards
Shane.
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
