I have searched and searched for a wiring diagram and have had no luck.
I don't particularly want to go joining wires until i find the right ones just in-case i cause a short and blow something.
On the auto there is 4 plugs, one with a 4-pin connector which goes into the side of the shifter on the drivers side of the box,
and on the passenger side of the box are 2 x 2-pin connectors and 1 single pin connector.
Which plugs and corresponding wire colours wires do what?
The auto box has overdrive so I'm guessing some of the wires are for this.
I need to bypass the inhibitor switch to get the car to start again as i have almost completed my manual conversion and also need to hook up the reverse lights.
Please HELP :/
I did ask this question in my other thread but am yet to get a response and i've been stuck for almost 2 weeks.:(
https://www.sau.com.au/forums/topic/369703-mr30-wiring-question/
Thanks Dennis,
I'm at work at the moment, i will give you a call when i can get back under the car either tomorrow or Monday if that is OK with you.
Will be great to hear the beast running again now that I've just preformed a service on it and added a pod filter, some extractors, 2 and a 1/4 inch exhaust system and a 6 inch cannon.
Regards
Shane.
Ok call me on 0406142529 and we can try sorting you out.
Cheers, Dennis
I have to go out, but when I return I'll post some pics of service pages so you can try to work it out.
Wiring colour codes are:
B = Black
W = White
R = Red
G = Green
L = Blue
Y = Yellow
LG = Light Green
BR = Brown
OR = Orange
P = Pink
PU = Purple
GY = Gray
SB = Sky Blue
In case of colour coding using a stripe, Base colour is first followed by stripe colour
eg. L/W = Blue with White stripe
Cheers, D
sweet thanks dude!!!
B = Black
W = White
R = Red
G = Green
L = Blue
Y = Yellow
LG = Light Green
BR = Brown
OR = Orange
P = Pink
PU = Purple
GY = Gray
SB = Sky Blue
Cheers, D
Hi Shane,
Attached is 6 pics.
Pict 0011 is the Ignition System
Pict 0010 is the Charging System
Pict 0009 is the Starting System
Pict 0008 is the Power Supply Routing
The second Pict 0009 is the Overdive Control System
The second Pict 0008 is the Kickdown Switch System
All these are for the Australian car.
From what I read in the manual, the 4 pin plug is from the Overdrive control switch, the 2 pin plugs are Kickdown solenoid & Overdrive cancel solenoid. The single appears to be the Overdrive indicator switch as well, possibly indicator light.
The Inhibitor switch also has 4 wires but I don't know where they go as I don't have any automatic vehicles to look at for you.
If these picture diagrams don't help, your more than welcome to come down and look at the manuals, as I'm just at Campbelltown.
Cheers, D
Thanks mate, those circuit diagrams were exactly what i needed.
All sorted now, it turns out that the 4 pin connector is all i needed to use,
just join the black/white wire to the green/yellow wire to bypass the inhibitor
and the yellow wire and the red wire to the manual gearbox reverse switch wires.
Regards
Shane.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
