Goodafternoon fellas',
Im having some issues with my car, before i go on, i would just like to say that my car standard apart from:
- Front pipes
- Hi-flo metal cat
- Apexi cat back
- K&N Pods apexi intake
Now my problem is, my car isn't lacking power, but it just chews fuel and i mean $50 petrol and im lucky to get 200kms if i drive like a granny possibly 250km. Now something can't be right? Is this just a normal occurance with GTRs? I've read on here that people get way better fuel economy. The car is due for service in another 500kms so looking at changing sparkies, oil, oil filter ect.
I've done my search, but nothing really hits the nail on head with my case. When the car got here, it was 100% stock except for the Apexi catback, Stock airbox front pipes ect ect.
Really would appreciate any feedback advice, and or whatever. Seeing as the car is my daily for the meanwhile its smashing me sick in the wallet.
Thanks guys.
If the O2s are the same ones from factory I would change them, then give the AFMs a good clean too. While you're at it, tighten up all your FMIC piping hoses, etc.
im getting 15l/100 on mine. have changed the o2 sensors as well. i do alot of around town driving though
Thats decent, mine works out to be 16.5l/100. Thats mixed driving; freeway and in and out of the suburbs.
$50 of 98 isnt that much these days, 200km from that isnt that bad.
i managed to get under 300km out of a full tank once.
get a new ecu for it (nistune, pfc etc...) and youll be able to tune it for much better economy
has the fuel economy gotten worse ? or have u just got the car and expected it to be better?
gtr's CHEW the fuel dude
Hrmm i dunno bro, I mean i've owned that car since last year August. I never remembered it being this bad. I mean it was thirsty but now its just stupid. It is kinda standard after all, expected it would be better :S?
I guess what im trying to ask is there anything i can do to, increase fuel economy?
Lol, but is it normal to say go from 4th to 2nd to say overtake then stretch the gear a bit, and once your in 5th cruisng you look at the petrol needle and see that it has drop? haha
plenty of factors to consider when looking at fuel economy. generally only use others economy as a rough guide as there are so many variables. here's a list of things to consider:
- do you let the car idle to warm up? (an idling car will use a few litres per hour)
- how long does the car take to warm up? (if more than a few mins when driving then get a new thermostat)
- how much time do you spend sitting in traffic?
- how hilly is it where you drive?
- how often do you go into positive boost?
- how much throttle do you apply at low rpm? (fuel economy has little to do with revs but throttle percentage. you can rev it out to 5000rpm using light throttle and get better economy than someone who only revs to 3000rpm but floors it to get there)
you can check a few things to help get better economy. o2 sensors are a good place to start. also worth jacking the car up and spinning the wheels to make sure you don't have a sticking brake caliper (or hand brake) or damaged wheel bearing.
- do you let the car idle to warm up? a few mins is enough (an idling car will use a few litres per hour)
- how long does the car take to warm up? warm up meaning halfway mark?
- how much time do you spend sitting in traffic? Not alot
- how hilly is it where you drive? Not at all
- how often do you go into positive boost? A fair bit, just normal driving
- how much throttle do you apply at low rpm? (fuel economy has little to do with revs but throttle percentage. you can rev it out to 5000rpm using light throttle and get better economy than someone who only revs to 3000rpm but floors it to get there) Quite alot, i normally am to lazy to drop a gear sometimes, so i just give it more gas
I'll be getting the o2 sensors and checking all these things in the coming weeks. Thanks mayn.
Also, I would see if the engine's thermostat is working. It might be seized and always opened. The ECU will dump in more fuel when the water temp is low, does your car's water take forever to warm up?
As Marc said, driving habits are the first thing to address if you want to see better fuel usage.
As for oxygen sensors, again, they do absolutely NOTHING if your driving style is heavy.
Do some Googling re-oxygen sensors and you'll see there are many factors that must be satisfied before the ecu will even go to closed loop.
For the majority of time you're running in open loop (no feedback) and the oxygen sensor input is ignored.
Biggest joke out, replacing oxygen sensors and then driving pedal to the metal.
As your problem is somewhat recent, my first look would be coolant temp sensor.
But don't just replace stuff willy-nilly, pay the $$$ to get everything professionally checked.
Come to think of it not really, about 4-5 minutes before the needle moves. This is in 5 degree weather (Melbourne)
boost is the enemy of fuel economy. by the sounds of it o2 sensors won't help your economy much as your driving style is causing your poor economy.
I personally get about 400-450ks to a tank on low boost (14psi/340rwhp) in a mix between driving 80ks a day a least with mixture of country back roads and highway driving nice and casually... but If i bump the boost up to highboost(21.5psi/467rwhp) it will chew very badly about 200-250 per tank.
So about 12.5/100 on a very very good run still not as thirsty as my mates Ve ss his worse fuel consumption was about 23/100 stock :S
I have changed the following
Power-Fc
2860-5s
Tomei Dumps
100 Cell Cat
Nismo 600cc Injectors
Nismo Fuel Reg
Nismo Fuel Pump
HKS Hard piping for intercooler
Cooling-pro Front Mount.
I am still running the stock AFMs but clean them regularly!
Clean your AFMs and Airfilter, Change your plugs etc.... My question is have you recently changed the oil brand/weight lately? I only ask as I changed my oil from 0-40w Castrol edge to Royal Purple 3-35w and I noticed a mass drop in response and reliability... so I changed the oil out a week later I also could hear the oil slapping on cold start.
Edited by EAT26
Power-Fc
2860-5s
Tomei Dumps
100 Cell Cat
Nismo Fuel Reg
Nismo Fuel Pump
Its going for a service soon, so hoping to change oils. Ive been using Motul 8100 5-40w fully sen since i started driving it on the road. So maybe a different oil could help? What do you guys reccomend?
Im also going to buy an ECUtalk cable of ebay, sus out shit some more, get a better idea of whats happening.
BTW, thats great fuel economy dude
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
